Radial on K75
Topic: Radial on K75 (Read 3998 times)
Gru
Motobrick Curious
Radial on K75
July 24, 2018, 11:36:45 AM »
I have a K75, 1995, with 3.0 tear three spoke wheel. I want to put a 15/70/17 rear wheel on, has a shim in the wheel, but the radial is 11mm wider than the stock bias tire. will it work, or will I have to add another shim.
Village Mills
K75, "CB 500x, Versys 1000, W650, FZ 07
15 Versys 1000, 15 FZ 07, 13 CB500X, 02 W650, 95 K75
johnny
TrailBrakingThrottleWhacker
Re: Radial on K75
Reply #1 on:
July 24, 2018, 03:58:15 PM »
i went 3 spacers with no adverse effects no tior rubb no off tracking whack...
all these things are tweaked... frames swingarm bushings wheels... gonna have to mess with it...
i can tell you to check tior rubb while the tiors are hot and loaded...
rbm
Re: Radial on K75
Reply #2 on:
July 24, 2018, 05:50:12 PM »
Too much shimming and you'll scrape the centre stand on the other side.
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
Gru
Motobrick Curious
Re: Radial on K75
Reply #3 on:
August 02, 2018, 10:06:29 PM »
The shims are closer to 1.3mm, hope three will be enough. Tires ordered, shims waiting to have some fun getting things lined up.👍
Village Mills
Radial on K75
