Author Topic: Mirrors!!  (Read 13405 times)
Offline 87K75S
Mirrors!!
« on: May 11, 2018, 11:05:39 PM »
Where can I get some mirrors that I can actually use to look behind me?  My 75S mirrors suck!!  They're not wide enough.  LOL
  • Washington
Brian
0346
K75S
Offline Skunky
Re: Mirrors!!
« Reply #1 on: May 11, 2018, 11:15:32 PM »
Or could it be that the rider is not narrow enough?   :dunno
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Offline 87K75S
Re: Mirrors!!
« Reply #2 on: May 11, 2018, 11:20:48 PM »
Could be but not in this case!
  • Washington
Brian
0346
K75S
Offline Skunky
Re: Mirrors!!
« Reply #3 on: May 11, 2018, 11:33:53 PM »
Hi just saw you're 75 on your other page. Very nice. The semi naked 75 has stem mirrors which are narrow. You could try Bar end Mirrors which would bring them out a tad.
  • Derby GB
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #4 on: May 11, 2018, 11:57:37 PM »
Some folks luv their Lolly-pops, others like Johnny recommend Ken Sean mirrors. I put the short-stem Ken Sean on a Marrakesh K75s and like the new look and the rear-view improved greatly. The standard mirrors are 8mm where the Ken Sean is 10mm, so you will need to tap the mounting holes for 10mm or make an adapter out of a connector nut - see hardware dept. at Home Depot. I like the result but it's personal preference. Will post a photo. :2thumbup:
  • Laguna Beach, CA
Offline 87K75S
Re: Mirrors!!
« Reply #5 on: May 12, 2018, 12:02:20 AM »
Yes!  Photo!
  • Washington
Brian
0346
K75S
Offline 87K75S
Re: Mirrors!!
« Reply #6 on: May 12, 2018, 12:05:06 AM »
I thought about bar ends but I think it would look too cafe-ish which I'm not interested at all...
  • Washington
Brian
0346
K75S
Re: Mirrors!!
« Reply #7 on: May 12, 2018, 02:07:00 AM »
I fitted auxiliary small bar end mirrors sourced from the local bicycle shop. With them fitted, it has eliminated all the previous blind spots.
* BMw K75 Home.jpg (73.7 kB . 768x576 - viewed 704 times)
Re: Mirrors!!
« Reply #8 on: May 12, 2018, 08:33:38 AM »
Yours are OEM short-stem. The OEM long stems give good coverage. The Ken Sean model discussed here is pretty good, too, and its angularity is fashionably compatible.
Re: Mirrors!!
« Reply #9 on: May 12, 2018, 09:07:05 AM »
the 100% yeeeehaaaa set up is ken sean ax or gx mirrors with fit system co400 blindspots on velcro on the top inside corner of the mirror glass... and these two components are optically correct for real world input...
can see everything without moving the head... just rolling the throttle and rolling the eyeballs...
i shall not fear death as i watch your headlight fade into the night as i ride tached to the redline through the valley of the deer...
http://www.ksource.org/
ride fearlessly...
Offline 87K75S
Re: Mirrors!!
« Reply #10 on: May 12, 2018, 10:31:19 AM »
Excellent!  Thanks for the great leads.  I will look into both.
  • Washington
Brian
0346
K75S
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #11 on: May 12, 2018, 11:29:24 AM »
Here are some photos of results.  Making the mirror pedestal is optional, you can also tap the handlebar mount directly.  The pedestal allows me to re-install the Lolly-pops if desired. May add the blindspot fisheyes next.   Does that help?   :popcorm
  • Laguna Beach, CA
Offline 87K75S
Re: Mirrors!!
« Reply #12 on: May 12, 2018, 12:45:37 PM »
What did you do?  Install an 8mm stud and then an 8mm to 10mm bushing?
  • Washington
Brian
0346
K75S
Re: Mirrors!!
« Reply #13 on: May 12, 2018, 01:30:59 PM »
those look good on that red s... what i did was spray it down real good with pb blaster... not the can... the 5 gallon bucket of the liquid stuff... i put it in a bug sprayer and soaked everything except seat and grips... then i runned a 10mm tap through the existing oe hoes... slow and easy... i wanted to finese it not force it... as i was only gonna getts 1 try to getts it in there straight and tight...
here they are with the fitsystem blindspot mirror on the brickus trukus...
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #14 on: May 12, 2018, 04:37:42 PM »
I used conventional hardware available from Home Depot, a 5/16 stainless bolt, a 5/16 connector nut.  Re-drill and tap the other connector nut end to 10mm X 1.5mm.  Check the thread pitch of your Ken Sean mirrors, they are 1.25 or 1.5mm I forget which.  Those of you with metric size hardware available can go all metric.
  • Laguna Beach, CA
Offline 87K75S
Re: Mirrors!!
« Reply #15 on: May 12, 2018, 07:55:39 PM »
I definitely like the look of a square mirror.
  • Washington
Brian
0346
K75S
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #16 on: May 12, 2018, 11:08:55 PM »
Agree!!  If you go this route get the Ken Seans or better, there are very cheap Asian knock-offs out there that are junk (I know I bought some).   :dunno2:
  • Laguna Beach, CA
Re: Mirrors!!
« Reply #17 on: May 13, 2018, 08:01:33 AM »
lmiklosy -  noticed the 2002 reflected in your mirror...yours?  I have had more than a few of those!
Re: Mirrors!!
« Reply #18 on: May 13, 2018, 09:05:41 AM »
Really nice!!!  The shape repeats the lines of the headlight much better than the lollipop version.  It's a little thing, but makes a difference.
I think a pair of those guys is going on my brick.
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #19 on: May 13, 2018, 10:30:00 AM »
I bought only one in 1975, drove it ever since.  It's a restoration project now, mechanically solid but the Utah salt eats cars!
  • Laguna Beach, CA
Re: Mirrors!!
« Reply #20 on: May 13, 2018, 10:55:00 AM »
looks like we both have two K75S's and a 1975 2002!
thanks for the detail on the mirror mod!
Offline 87K75S
Re: Mirrors!!
« Reply #21 on: May 13, 2018, 11:19:07 AM »
^Wow!! That's impressive!
I had an Avus Blue E36 M3.  Or is that Techno Violet?
  • Washington
Brian
0346
K75S
Re: Mirrors!!
« Reply #22 on: May 13, 2018, 01:21:32 PM »
techno violet
Offline 87K75S
Re: Mirrors!!
« Reply #23 on: May 13, 2018, 01:27:15 PM »
And I had an 81 SC!
  • Washington
Brian
0346
K75S
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Mirrors!!
« Reply #24 on: May 13, 2018, 09:21:17 PM »
Yawn,  I have one of those too, '85 Snap-On restored,  sport wheels. Needs struts.  bmp
  • Laguna Beach, CA
