Repair Guidance
Ground wire to battery?
Topic: Ground wire to battery? (Read 2843 times)
kmark
Curious
April 10, 2018, 05:20:14 PM »
I have a question. Does this cable (under thumb in picture)go to the ground side of the battery? I know the small one goes to the tab on the computer, just wondering about the one with the ringed terminal. I appreciate the help
NY
1992 k75; 1994k1100rs
rbm
Re: Ground wire to battery?
Reply #1 on:
April 10, 2018, 06:06:19 PM »
If the far end of that cable goes down to the gearbox housing on the left side of the bike, then yes it is a ground cable. If it disappears into the relay box, then no it is not a ground wire.
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
Chaos
Administrator
Mars needs women!
Reply #2 on:
April 10, 2018, 06:32:11 PM »
Whatt he said. Other end should be bolted to GB.
sw ohio
1987 K75S VIN 0231
Inge K.
Reply #3 on:
April 10, 2018, 06:50:11 PM »
Yes, other end is normally connected to the gearbox at the inner mounting bolt for the starter.
Norway
