Author Topic: Rate My Splines  (Read 5054 times)
Offline lilau3
Rate My Splines
« on: March 09, 2018, 07:13:08 PM »
Hi Motobrickers,
So I dropped the final drive off today to check out the condition of the splines.
Everything seemed to be covered in a fine layer of red grease but it was probably fairly dry.
Is the red stuff BMW origonal?
How would you rate the condition of these splines?
Images attached.
Thanks in advance.
  • Australia - Melbourne
  • 1988 BMW K100 LT, Vespa GTS300
Re: Rate My Splines
« Reply #1 on: March 09, 2018, 07:22:12 PM »
Those pictures look pretty good to me.  What I look for is a nice wide flat spot at the top of the spline, on both parts.  A nice sharp corner at the edge of the flat is also nice.
As the splines wear, the flat at the top gets narrower, and the banging between the parts rounds off the edge.  You need to clean them good to get a good view of what is going on.
Offline lilau3
Re: Rate My Splines
« Reply #2 on: March 09, 2018, 08:35:23 PM »
And here is the spline from the transmission. Is that groove normal?
Re: Rate My Splines
« Reply #3 on: March 09, 2018, 09:07:12 PM »
The groove is normal. A snap ring inside the driveshaft u-joint fits into that groove to hold the driveshaft to the output shaft.
  • 1995 K75 89,000 miles
Offline lilau3
Re: Rate My Splines
« Reply #4 on: March 09, 2018, 10:28:37 PM »
Really! I didn’t remove any snap ring to pull the driveshaft off.
Re: Rate My Splines
« Reply #5 on: March 09, 2018, 10:31:34 PM »
The ring is inside the spline on the u-joint.  It stays in there when you pull the shaft.
When you pulled the shaft off the transmission output spline you did feel resistance didn't you?
Offline lilau3
Re: Rate My Splines
« Reply #6 on: March 09, 2018, 10:43:20 PM »
Yes I did. I levered it off.
Offline blackie1
  • christchurch nz
Re: Rate My Splines
« Reply #7 on: March 10, 2018, 12:40:58 AM »
ooh nice splines
how many km's on the clock?
  • 1991 K75RT naked 67,000kms
Offline lilau3
Re: Rate My Splines
« Reply #8 on: March 10, 2018, 03:30:21 AM »
ooh nice splines
65,000kms supposedly.
Re: Rate My Splines
« Reply #9 on: March 11, 2018, 10:09:17 AM »
The ones from about 10 o'clock to 2 o'clock look suspect to me, but maybe it's the lighting or residual grease.
Best way to photograph splines is looking straight down them.
http://www.motobrick.com/index.php?action=dlattach;topic=10928.0;attach=62313;image
