Back from the dead with a new problem. :musicboohoo: After riding my K this past summer, I've decided to return to a problem that I've been having.
As some of you might know, I created a thread on this about a year ago, but did not have any of the new information that I now have. Also, completely rebuilt the K about a 18mo. ago and haven't been able to ride it much...
I noticed a symptom of my K (85' K100) possibly running rich. That is:
**when the oil-cap is removed, the K runs a whole-lot better.**
My guess is that its running rich. Searches on this topic reveal that on a working K bike, if you remove the oil-fill cap, it should run rough.
Possible causes:
- Fuel reg. is leaking extra fuel into intake via hose
- AFS (MAF) is in need of a tune/adjustment
- Valve adjustment?
Symptoms: ??
- Throttle works up to 75%. After 75% or WOT, the K does not do anything. In-fact, it looses a bit of acceleration- slight lurching?
- Spark plugs foul too often
- Low gas mileage ~30?
- Black spray comes out of exhaust pipe during start-up. (SEE PICTURE OR ATTACHED)
*Does the K run rich on immediate start-up (while button is pressed), or does it run rich until it warms up?*
During start-up I'll have the "throttle-advance" on 1st notch. Then about 3-5 minutes later, the RPM's suddenly jump up (1000-2000?), and then the throttle is returned to normal.
Also, earlier this week, I was testing to see if the cooling fan would come on (200f?), so I had the K running in my driveway. It got to about 150F and then shut-off. I had to WOT the throttle to even get it to start and it ran really-rough. I rode the K and it was apparent that only 3 pistons were firing.
I dont know if any/all of the problems listed are related or not. Help would be greatly appreciated! :2thumbup:
