Author Topic: Running Rich? Oil filler cap removed = runs better  (Read 18856 times)
Offline jjs1234
Re: Running Rich? Oil filler cap removed = runs better
« Reply #25 on: March 08, 2018, 05:29:17 PM »
Well I believe I fixed the problem...
Guess what it was [emoji23]
Injectors (4 hole injectors that other people have used here).
  • Northern California
  • 1984 K100
Mr. Creative
« Reply #26 on: March 08, 2018, 05:35:32 PM »
So you installed the old injectors and everything is just peachy now?
Offline jjs1234
« Reply #27 on: March 08, 2018, 05:39:18 PM »
Yes. Absolutely. (Apart from some intermittent fasting nocking noise on the right-side of the bike that came and went during the ride)
When I open the oil fill... It almost dies. And the rpms barely change upward when the starter button is pressed under 1000rpm. It also does not lag under WOT.
  • 1984 K100
Mr. Creative
« Reply #28 on: March 08, 2018, 05:57:18 PM »
 :2thumbup: Good to see it's fixed. Did you ever have it running properly with the 4 hole injectors? Were they new? What model vehicle were they originally made for? I nearly bought a set of 4 hole injectors. But due to the lack of solid evidence like Dyno figure comparisons of 4 hole versus a set of clean good condition OEM injectors I resisted the urge. Instead I built a test rig and bought a injector pulse unit. After cleaning my old injectors and getting the spray pattern right I experienced a noticeable difference and also it cured the last little bit of back firing on over run. I concluded that until dyno figures are produced there is no benefit to be gained with 4 hole versus CLEAN OEM. And as Gryph has pointed out the 4 smaller holes would be more susceptible to blocking.
Offline jjs1234
« Reply #29 on: March 08, 2018, 06:04:22 PM »
Never got it working with the 4 hole. Maybe the later model Ks can adjust to compensate for more fuel? I have no idea what model BMW they were for... But it was from a BMW sedan. Someone on the forum said they were better (infact more than just 1 person)- theirs a post on here somewhere.
I think the 4 hole spray 20% more fuel or more.
But she ran like a champ and acceleration was amazing.
Just gotta figure out that intermittent nocking noise...wtf [emoji53]
  • 1984 K100
Mr. Creative
« Reply #30 on: March 08, 2018, 06:16:55 PM »
Virtually most of the time the 4 hole injectors are used it would to be to replace old possibly partially blocked injectors. And by replacing them with clean 4 hole injectors with the correct spray pattern of course you are going to feel an improvement. Maybe 4 hole injectors are better but I have never seen a proper objective comparison one way or the other. All  4 hole testing including mine was done with a Butt Dyno. However my injectors had a couple of bad patterns and once spraying correctly you could feel a noticeable difference. If I had replaced them without checking them with the 4 hole ones I too would be singing the praises of 4 hole injectors.
