You can edit posts once you hit the magic number (of posts). I think it's 10??
20 years, you are probably going to be looking at seals and rubber bits all over. Brake lines, fuel lines (in and outside the tank), throttle body rubbers, the infamous "Z" tube, etc. Tear it down far enough to look at the TBs, I couldn't see mine were cracked until I got them off.
Also look at a spline lube, trans and driveshaft.
I'm sure others will chime in as well...
Jim
