Author Topic: Installing 2002 k1200Lt water pump on 86 k75.  (Read 6829 times)
Offline Gumbo
« on: October 28, 2017, 10:16:58 AM »
 Hey Yall I have a 1986 k75t with 35,000 miles as a Project Bike needing work, I installed a 2002 k1200Lt water pump on my Bike and No more Leaks,  My Question is There's no Small hole up top of the pump for the small Relief hole on the engine block,  is this Going to be A Problem down the Road????  Thanks for any info.
  • Houston, Texas
  • 1986 k75
Offline Gumbo
Re: Installing 2002 k1200Lt water pump on 86 k75.
« Reply #1 on: October 28, 2017, 11:08:33 AM »
 I want to post some Pics but it's Like pulling Hen teeth!!! :dunno2:
  • Houston, Texas
  • 1986 k75
Offline Gumbo
« Reply #2 on: October 28, 2017, 11:15:29 AM »
  • Houston, Texas
  • 1986 k75
« Reply #3 on: October 28, 2017, 11:59:50 AM »
Shouldn't be a problem.  The pump design around that area changed in the later years; see the pic below:
Just make sure to keep that semi-circuilar hole on the engine block cleared by passing a wire through it to push out any accumulated gundge when the pump is off the block.  And make especially sure not to block that semi-circular hole with sealant when refitting the pump.
Offline Gumbo
« Reply #4 on: October 28, 2017, 12:19:42 PM »
  Yes that's what I was talking about,  Thanks rbm I did make sure it was clear and not blocked... on the new pump there's nothing but flange surface so I put the Sealant as normal..
  • Houston, Texas
  • 1986 k75
Offline Gumbo
« Reply #5 on: October 28, 2017, 12:36:10 PM »
* 5328-271017190601-7861734.jpg (44.33 kB . 432x576 - viewed 608 times)
  • Houston, Texas
  • 1986 k75
Offline Gumbo
« Reply #6 on: October 28, 2017, 07:25:53 PM »
 The k1200 water/oil Pump
  • Houston, Texas
  • 1986 k75
Offline Gumbo
« Reply #7 on: October 28, 2017, 07:27:54 PM »
  My bike
  • Houston, Texas
  • 1986 k75
Offline blackie1
  • christchurch nz
« Reply #8 on: October 29, 2017, 02:56:04 AM »
looks in good nick.
if you rotated that pic a further 90 degrees clockwise it would be perfect viewing for us riders down under
  • 1991 K75RT naked 67,000kms
« Reply #9 on: October 29, 2017, 06:35:04 AM »
Nice bike, and nice truck! Keep the pictures coming.
Offline jay1622
« Reply #10 on: October 29, 2017, 12:42:38 PM »
Good morning Mr. Gumbo! I rebuilt an engine & water/oil pump last year very similar to what you have going on. I remember trying to figure out why nothing I had matched up with the book and other web-based info and stuff. More importantly, my concern was that the weep hole in my engine block didn't match up with the existing pump. I followed the sealant route pictured above, and I've yet to experience any issues; about 6k miles later. Best of luck with your brick!
  • Charlotte
Offline F14CRAZY
« Reply #11 on: November 04, 2017, 06:56:12 PM »
I've put like 20k miles on a K1200LT pump on my K75 and it's been fine. I got tired of trying to reseal the old one so I just bought a used one off ebay
  • Grand Rapids, MI
  • '87 K75C
Offline Gumbo
« Reply #12 on: November 04, 2017, 09:24:21 PM »
  Exactly what I did,  only My original oil gear drive is 19 tooth count like the k1200Lt pump so everything lined up perfectly and No More Leaks!!  Thanks F14 for the Original Post.....Gumbo.
  • Houston, Texas
  • 1986 k75
Offline Gumbo
« Reply #13 on: November 04, 2017, 09:25:32 PM »
 Hey Bill, Thanks Brother....
  • Houston, Texas
  • 1986 k75
