Author Topic: Oil sight glass  (Read 7034 times)
Offline JPaganel
Oil sight glass
« on: October 18, 2017, 01:19:29 PM »
My R-bike popped the sight glass this morning. Oil all over the place...
This glass is the same as the K. Literally same part number. The stupid thing is press-fit in the block from the outside.  WTF were you thinking, BMW?
First of all, is there a "new and improved" version of that?
Second, has anyone just tapped that hole and put in a standard industrial glass?
Seems like you would be able to use something like this: http://www.globalindustrial.com/p/fasteners/machinery-hardware/fluid-level-sight-glasses/aluminum-fluid-level-sight-glass-w-o-reflector-m27-x-1-5-thread-r05-b?info
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Re: Oil sight glass
« Reply #1 on: October 18, 2017, 02:52:20 PM »
Quote
Find an R forum or BMWMOA, lots of fixes out there.
Those people are not fun like you guys.  Paid memberships, join approvals... I am still waiting for them to give me the OK to post.
Re: Oil sight glass
« Reply #2 on: October 18, 2017, 08:14:18 PM »
In all my years here I can recall one member having his K bike sight glass blow out. (Anyone else remember Crapdealer Bob?)
Have heard it said that the problem is worse with R bikes because of the pressure pulse of pistons going in and out together.
Some on here have replaced cloudy sight glasses. Drill a hole in the existing one, run in a self-tapping screw, grab the screw with a pair of Vice Grips and pull the glass out. Tap in the replacement and go ride another hundred thousand miles.
Re: Oil sight glass
« Reply #3 on: October 18, 2017, 08:55:17 PM »
my original post seems to have disappeared except for the quote.  I described that in R bikes crankcase pressure peaks when both pistons are at their lowest position simultaneously.  You don't get that with a K bike layout so the sight glass is not as likely to pop out.  I have never seen it happen on a K but know of lot's of R's it's happened to, sometimes catastrophically.
Offline Michael Sydney
Re: Oil sight glass
« Reply #4 on: October 19, 2017, 08:20:52 AM »
My R bike has a reed valve in the crankcase breather to ensure a low pressure within to overcome the problem of compression in the crankcase when both pistons are on the "down" stroke.
Could it be that the sight glass blows out due to a problem with the crankcase ventilation system?
  • Sydney Australia
  • K100 R65
Offline Blue
Re: Oil sight glass
« Reply #5 on: October 19, 2017, 11:54:29 AM »
Transparent plastic cork for magnum bottle.
  • Stovepipe Wells CA
  • 1995 K1100RS
Offline JPaganel
Re: Oil sight glass
« Reply #6 on: October 19, 2017, 12:32:47 PM »
What is going on with this thread?
First, Chaos's post disappears, now my post shows up under his name...
Go home, SMF, you're drunk...
  • Minnesnowta
Re: Oil sight glass
« Reply #7 on: October 19, 2017, 01:30:49 PM »
You know what's weirdest of all?
A thread about R-bikes on Motobrick.
Offline bizzaro
  • co pilot
Re: Oil sight glass
« Reply #8 on: October 19, 2017, 01:49:52 PM »
:hehehe
Oh, Shit, mine is leaking........better pay attention! :popcorm
  • Vermont
See Ya in the Twisties,
 Bizz
Offline jaxon
Re: Oil sight glass
« Reply #9 on: October 19, 2017, 03:27:22 PM »
My sight glass appears to have cataracts due to age.
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
Re: Oil sight glass
« Reply #10 on: October 19, 2017, 04:46:40 PM »
It might be a sign to ride by faith and not by sight.  :oldguy:
Offline JPaganel
Re: Oil sight glass
« Reply #11 on: October 19, 2017, 05:37:59 PM »
If you wanted to replace it, it shouldn't be hard to pry it out.
I just found a place that has them for $30 instead of the $45 everyone has them for.
http://www.beemershop.com/Merchant5/merchant.mvc?Screen=PROD&Product_Code=ENA60774
  • Minnesnowta
Offline F14CRAZY
Re: Oil sight glass
« Reply #12 on: November 04, 2017, 07:15:05 PM »
ah, dem motoboxers...reminds me of when I borrowed an R1100RTP from the dealer...first time on a motoboxers...side to side vibration? Check. Sounds like a sewing machine? Check. It was even surging!
  • Grand Rapids, MI
  • '87 K75C
