Author Topic: I think I figured out my crappy mileage.....  (Read 4320 times)
« on: October 14, 2017, 05:52:47 PM »
it just kept getting worse :dunno ,  these were shot a couple days and a full tank of gas apart, I suspected the odo might be getting flakey this pretty much confirms it.  Anyone got an old cluster with good gears really cheap, like for postage :hehehe
Re: I think I figured out my crappy mileage.....
« Reply #1 on: October 14, 2017, 06:02:45 PM »
New gears are available, the OEM ones are actually made out of cheese or tofu.I had mine disintegrate at 140,000 Ks. It's not hard to do them just be gentle.
« Reply #2 on: October 14, 2017, 10:38:02 PM »
Www.odometergears.com
Great guys to work with.
« Reply #3 on: October 15, 2017, 12:42:42 AM »
this will be my 3rd set.  I think I'll just figure mileage by the stars and low fuel warning light for a while
« Reply #4 on: October 15, 2017, 01:19:35 AM »
I was told by an instrument restorer in Brisbane not to lubricate the gears. Apparently the lube can react with the gears turning them into cheese, tofu.
« Reply #5 on: October 15, 2017, 06:43:50 AM »
Here's an article that suggests your problem with the odometer might be with the pins of its electrical connector instead of its gears.
http://www.k100.biz/Electr/_NT/NT_speedo_repair.pdf
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #6 on: October 15, 2017, 12:51:51 PM »
By the sounds of it, looks like you've replaced them before....however, If it comes down to replacing the gears...it's actually not too much a daunting task...I did it, you can too.....True, I've been told NO LUBE on the replacement gears...run them dry.
Tutorial here:  http://m.odometergears.com/documentation/BMW_Motorcycle_MotoMeter_Odometer_Gear_Replacement-.pdf
  • Austin, TX
