Author Topic: 1983 K100 oil?  (Read 6489 times)
Offline imncrxtc
1983 K100 oil?
« on: October 13, 2017, 04:48:48 PM »
I have had my K100 for a few years, i have never started it, i just brought it home from storage. I noticed the oil level (when on the center stand) is not visible. I only see it when i go from kick stand to center stand. My question is, do i have too much oil, or not enough oil?
It its storage unit, it leaked about a 10" round oil marking on the floor over 3 years. I want to start it up tonight, but im worried there isn't enough oil.  Also, what type and weight oil should i use?
  • Toronto,  Canada
  • 1987 K100
Re: 1983 K100 oil?
« Reply #1 on: October 13, 2017, 05:20:26 PM »
When on the center stand the oil level should be about half way up the sight glass.  Typically that would mean clear on the top half and black or dark brown on the bottom half of the glass.  If it is black all the way up the sight glass when on the center stand you have too much oil, but I would not let that stop you trying to start it as long as you have put in clean gas, charged the battery and all the other long list of things recommended on the site before firing up a bike that has been dormant for a long time.
Offline ^Adrninistrator
  • Acute Cinnabar Toxicity
  • Brunhilda Baywerische-Motosenwerken
Re: 1983 K100 oil?
« Reply #2 on: October 13, 2017, 07:38:31 PM »
imncrxtc:
I am Acute Toxicity (formerly Brunhilda),  the Special Agent In Charge at the DMJ (Department Of Motobrick.com Justice).
The BMI (Bureau Of Motobrick.com Investigations) has confirmed that you violated motobrick.com protocol by not exhausting the search options available at motobrick.com.
This is your notification that another occurrence will trigger disturbing sanctions.
The protocol is located here for your review and compliance as defiance is futile.
A T
  • New Idria California
  • 1997 K 1150 RS SE Dakar Yellow Code 267
If You Are Looking For Trouble. I'm The Woman To See.
If You Are Looking For Satisfaction.  Email Me.  Satisfaction Guaranteed.
brunhilda.baywerische-motosenwerken@motobrick.com
Re: 1983 K100 oil?
« Reply #3 on: October 13, 2017, 08:02:17 PM »
if you see the oil level when it's on the side stand you have way to much oil in it.  Check it on the center stand. Often the sight glass gets dirty making it difficult to see.  Best bet would be to drain it, change the filter (Delco PF53 is available everywhere) and refill it with 4 qts of a name brand 20-50 or 20-40.
Offline Blue
Re: 1983 K100 oil?
« Reply #4 on: October 14, 2017, 09:24:11 AM »
Wurth Triathlon Premium M mineral oil 15w-45 / 2% Molybdenum.
  • Stovepipe Wells CA
  • 1995 K1100RS
Re: 1983 K100 oil?
« Reply #5 on: October 14, 2017, 10:37:14 AM »
I would recommend avoiding the addition of molybdenum to the engine lubrication system.  The starter's sprag clutch relies on a bit of friction on it's internals to operate properly in a reliable fashion.  Molybdenum is too slippery and even a tiny amount may prevent you from using your starter.
I found out the hard way...
Offline Blue
Re: 1983 K100 oil?
« Reply #6 on: October 14, 2017, 10:47:57 AM »
Factory powder perhaps.   Not mineral intrinsic.
  • 1995 K1100RS
Re: 1983 K100 oil?
« Reply #7 on: October 14, 2017, 05:16:56 PM »
Blue I'm with Gryph on this one, however it is always good to see experimentation. Please keep us updated on your starters progress or lack of progress. :popcorm
Re: 1983 K100 oil?
« Reply #8 on: October 14, 2017, 05:29:08 PM »
yeah, K motors run fine for hundreds of thousands of miles on oil with no moly.  Even if it doesn't hurt the sprag  why bother?
