Author Topic: drive shaft destroy k100rs 1991  (Read 8036 times)
Offline Kevinb
« on: October 03, 2017, 10:25:33 AM »
Hello everyone,
I'm in Montreal, Canada, I have a K100rs 1991 that as being started cafe by the previous owner.
I made the mistake to belive him when he told me the spline has been maintenance not long ago, the bike was in descent shape, so I had no reason to not belive him. Big mistake, what would have been a 1h job last week became a nightmare!
So I'm seeking advice, first I toke pretty much everthing appart, the final drive as no damage (tx motorcycle god), the U-joint is completly destroy and the shaft itself as the surrounding rubber partialy damage (but maybe by time), see picture
so :
1-should I replace the shaft as well, or it fine like that?
2-can other part as being damage by that destruction?
3-is there other model that are compatible, just u-joint or shaft
4-any idea where to find those part in Canada?
5-I eard about a specific grease for that, what the name and where can i find it?
6-anything esle here I should considere?
Thank you in advance
Kevin
  • Mexico Puerto Morelos
  • K100rs 1990
Offline Blue
Re: drive shaft destroy k100rs 1991
« Reply #1 on: October 03, 2017, 10:34:19 AM »
Am I the only one who can not see the photos of this completely destroy u-joint and nightmare drive shaft?
  • Stovepipe Wells CA
  • 1995 K1100RS
Offline Kevinb
« Reply #2 on: October 03, 2017, 10:36:14 AM »
Sorry
  • K100rs 1990
« Reply #3 on: October 03, 2017, 10:39:49 AM »
Photos need to be directly in front of the shaft and clearly focused, Kevin.
Offline Kevinb
« Reply #4 on: October 03, 2017, 10:47:44 AM »
the teeth are fine, it's the rubber that worries me, that why the angle, and the focus got lost in the downgrade quality to be able to post it  :(.
Tx
  • K100rs 1990
Offline Blue
« Reply #5 on: October 03, 2017, 10:54:11 AM »
The U-joint is not completly destroy?
  • 1995 K1100RS
« Reply #6 on: October 03, 2017, 10:57:41 AM »
How come I have three K75 driveshafts lying around and none of them have any visible rubber? Is that a K100 thing?
Offline Kevinb
« Reply #7 on: October 03, 2017, 10:58:00 AM »
No, it's tottaly fuck
  • K100rs 1990
Offline Blue
« Reply #8 on: October 03, 2017, 01:52:11 PM »
When my u-joint looked suspect, I got an OEM match from Rock Auto.  I do not have that K100 any longer or I would look up the nomenclature for you.
I think there may be cheap u-joints from China that may fit.  I think there are a few members here that go for cheap alternatives from China.
  • 1995 K1100RS
Offline barrydm
« Reply #9 on: October 05, 2017, 02:25:23 PM »
I just did the same job on my 1990 K100rs. My u-joint was blown apart just like yours. I ended up getting a used drive shaft ass'bly from a wrecker in the UK for a not unreasonable amount of money; plugged it in and away I went. Pretty straight-forward job and not a lot of money
  • british columbia canada
  • 1990 k100rs,Ducati S2R1000,BMW R1150S,1998 HD Fatboy,1974 Bultaco Sherpa T
« Reply #10 on: October 05, 2017, 03:18:14 PM »
Is this what happens when the u-joints aren't phased properly, or is it caused by something else?
Offline Kevinb
« Reply #11 on: October 17, 2017, 11:33:11 AM »
Hi,
I don't know if it was phasing, I just got the bike and it was completely destroyed when I opened the casing, that would be pretty dum doh, it's very simple too phase.
Since I didn't get any advice I went with what I thought, I keep the drive shaft, just got a use U-Joint from a UK shop name Motorworks, great service, the part was A1.
And because I'm doing all my mechanic in the streets, I will bring the bike to BMW, so they can check for further damage and lube the spine at the same time.
And funny, I can't find any of the BMW recommended grease in Canada, so, just for the transport purpose,I put red n tacky, I'm sure it's shit, but that will make it for the transport.So basically, I still have all the same interrogation, but winter is coming, no time to wait, so I will pay for the answers.
thank you
  • K100rs 1990
Offline John Lang
  • John Lang
« Reply #12 on: October 17, 2017, 04:09:51 PM »
Honda M-77 'assembly paste' is available in Canada -- see nearest Honda dealer. Make sure the contents of the tube have not separated into a gray liquid and a hard black lump before squeezing the tube and losing the liquid. If separation has occurred, cut open the tube and re-mix the solid and the liquid with a spoon before applying.
Laitch suggested Loctite LB 8012 Moly Paste. This should be available in Canada.
Bon chance.
  • Ottawa, ON Canada
Offline Kevinb
« Reply #13 on: October 18, 2017, 08:02:10 AM »
Thanks mate,
she's going to BMW today, so I guess they will put the NBU30
But I will look into it for the futur
Thank you
  • K100rs 1990
Offline Kevinb
« Reply #14 on: October 20, 2017, 07:50:23 AM »
Sorry
So to respond at that question, yes, that drive shaft is done, that rubber is like the anti-shock system of the drive shaft, so back to ordering parts online!
  • K100rs 1990
