Author Topic: Turn signal/flasher relay buzz  (Read 8345 times)
Offline Tricked919
« on: September 28, 2017, 11:53:56 PM »
I'm Installing new controls. EVERYTHING works except for turn signals ...yes, LED. And I'm only running rear signals (no front). When I hit the left blinker the blinker relay (green box) makes awful buzzing sound, hit the right... different awful buzzing sound. It won't turn off until I kill the power. I tried a 6 ohm resistor and still does it. Keep in mind the circuit for the fronts are still open. So, the questions...
1. What am I missing? I've read all the posts on cutting the trace on the circuit board but it seems like all thse posts were simply for a no-flash condition. My buzzing won't go away until I kill the power and remove the key from the ignition. Wierd stuff. I don't want to bust into the relay if this is a bigger issue.
2. My new switch has 3 wires (power, left and right) and the BMW harness has 5 (a cancel wire and a dimmer - neither being re-used). Can i just cap those?
3. What do I do for the fronts to properly close the circuit so it doesnt think I have a bulb out? Or is that even a problem. I do not plan on running front indicators (not required where I live)
Thanks everyone!
  • WNC
  • 86 K100, 04 RC51, 04 919
Re: Turn signal/flasher relay buzz
« Reply #1 on: September 29, 2017, 04:51:18 PM »
To achieve what you tryin' isn't possible with the OEM relay that easy, you need to buy a different one....
http://www.ebay.com/bhp/led-turn-signal-relay
The main problem is your new switch, which is meant for a ordinary relay...non BMW.
« Reply #2 on: September 29, 2017, 08:41:22 PM »
Best of luck on your journey onto the unknown.  Here is another possible solution:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/diyledrelay/diyledrelay.htm
Offline pedrofranca
« Reply #3 on: February 16, 2018, 01:57:13 PM »
Hey, I am having the same issue here. I have removed all lights from the bike - everything worked fine before that. Then, I installed 2 regular bulbs as front blinkers and two LEDs on the back with 6 ohm resistors on each. The blinkers stay lit - very dim - and the flasher unit buzzes as I turn the blinkers on. It stops buzzing when I shut down the blinkers. I am using the stock controls. Thoughts?
  • San Diego
  • k75 RS
« Reply #4 on: February 16, 2018, 06:18:26 PM »
Discussed in many threads on this forum.  Here's one with lots of information:  http://www.motobrick.com/index.php/topic,659.0.html
TL;DR = get rid of the ballast resistors and modify the OEM flasher module to eliminate the resulting hyperflashing. Don't use 6 Ohm ballast resistors to simulate an incandescent bulb.  That might work well for Jap bikes but this is a BMW.
« Reply #5 on: February 17, 2018, 09:48:45 AM »
Are you insane?
