Author Topic: Gauging oil level  (Read 6699 times)
Offline Altevogt
Gauging oil level
« on: September 16, 2017, 09:10:41 PM »
Without setting my 91 K100 on it's center stand is there any way of accurately guaging the oil level by observing the oil level in the window?
  • Edwardsville, KS
  • 1991 BMW K100LT 67K when purchased
Current bike;
1991 BMW K100LT
1976 Honda Gold Wing
1973 Yamaha TX 750
1964 Harley dresser (original 50 kick disappointment)
1971 Kawasaki 500
(????) Kawasaki 175 trail bike (it was blue)
Offline Blue
Re: Gauging oil level
« Reply #1 on: September 16, 2017, 09:25:25 PM »
You could have somebody sit on it flat footed and hold it still while you stick the gear box and eyeball the engine site glass.
  • Stovepipe Wells CA
  • 1995 K1100RS
« Reply #2 on: September 17, 2017, 09:26:38 AM »
Why not just put it on the centerstand?
« Reply #3 on: September 17, 2017, 09:35:14 AM »
Was the center stand damaged? I read in a previous post the side stand on your bike was damaged and repaired. Does your bike still have its lift handle?
Offline Altevogt
« Reply #4 on: September 17, 2017, 10:28:27 AM »
The center stand has been replaced and the kickstand now works flawlessly. I'm the problem, I'm old and getting it on the stand is an iffy process at best.
  • Edwardsville, KS
Current bike;
1991 BMW K100LT
1973 Yamaha TX 750
1971 Kawasaki 500
« Reply #5 on: September 17, 2017, 03:34:54 PM »
I built a drive in push out front wheel clamp when I did my rear main seal. If you have a welder they can be built or they have been made out of wood. Virtually what you are aiming at is two braced vertical supports wide enough to allow your wheel in, additional tie down straps can be added. Mine resides in the back shed and is a pain to extract but if needed pictures can be taken and posted. it is no work of art and was thrown together out of what I had at the time in a very short time. They can be bought new on line however they have a pivoting action that could make the bike just as hard to extract.
Regards Martin..
« Reply #6 on: September 19, 2017, 12:13:39 PM »
Another option could be an inspection mirror on a rod. Stand the bike up, put the mirror down so you can see. They even have some on telescoping rods, so you could keep it with you on the bike.
« Reply #7 on: September 20, 2017, 04:24:42 AM »
Brilliant! Here's a likely candidate.
Offline Blue
« Reply #8 on: September 20, 2017, 05:43:40 AM »
Camera phone on a selfie stick. But that is no help for gear box and final drive.
  • 1995 K1100RS
« Reply #9 on: September 20, 2017, 09:17:37 AM »
Drain and refill with exact volumes, plus a slight over fill night be an option.
Sent from my SM-G900V using Tapatalk
