Author Topic: Fuel tank  (Read 7489 times)
Offline jjconeill
Fuel tank
« on: August 27, 2017, 05:59:39 PM »
after replacing the fuel tank electric connector with a trailer hitch connector, recommended on this site, Thank You. my gas pill shaped light comes on at 130 miles, however that is only 3 gallons of what I believe is a 5.5 gal tank. the pill shaped light seems to be towards the right side of the pill shape, doubt if there is another bulb to the left side when less gas is available. So Tuesday I will put a gallon can of gas in my side bag and see how long it takes to run dry. Before the light worked I would go 180 miles than fill up, cant' remember quantity that was. any suggestion's on how to get the light to delay with say one gallon for reserve? the sending unit was replace by a dealer who thought it was faulty as was the fuel pump, they did not diagnose the connector. Thanks.
  • Lindenhurst Illinois
  • k75 1987
Re: Fuel tank
« Reply #1 on: August 27, 2017, 08:56:33 PM »
The sender unit is adjustable by moving a toothed wheel. Be gentle.
* Fuel sender adjustment.jpg (36.54 kB . 768x471 - viewed 555 times)
Offline White Dog
Re: Fuel tank
« Reply #2 on: August 28, 2017, 08:59:48 AM »
To delay the idiot light illuminating, turn the gear wheel CCW.  Be gentle, as Martin said.  Those teeth can easily be broken off.  Don't ask me how I know.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Re: Fuel tank
« Reply #3 on: August 28, 2017, 09:16:36 AM »
Yes, I can see that being a possibility.  The wheel is riveted using a nylon rivet.  It is understandably tight because it has to be set and remain at that setting in a very harsh environment, so there is lots of friction.  That's why I recommend levering against one of the metal tabs you will see poking up near the wheel.  Use a thin 1/8" straight blade screwdriver and work carefully.
Re: Fuel tank
« Reply #4 on: August 28, 2017, 09:32:07 AM »
Here's another view of the situation
Offline John Lang
  • John Lang
Re: Fuel tank
« Reply #5 on: August 28, 2017, 09:41:29 AM »
Why not simply bend the float rod downward (if signalling too soon) or upward (otherwise)?
  • Ottawa, ON Canada
Re: Fuel tank
« Reply #6 on: August 28, 2017, 10:12:35 AM »
Some people want to operate a toothed wheel, John, because it's there. Doing so helps bring order to a chaotic universe.
Re: Fuel tank
« Reply #7 on: August 28, 2017, 10:59:23 AM »
Because bending the arm changes the relative position of the wiper on the fuel level resistor to which the arm is connected, affecting the reading on the fuel gauge (if the bike is equipped with one).  Altering the contact point for the low fuel indicator using the BMW-provided adjustment wheel does not upset the fuel level sender.  Why "McGiver" it if you can do it properly?
The adjustment process is easy:
1. Take out the sender and set it up on the bench so that the float ball just touches the table top in its resting position.  Fix the sender's base.
2. Use an ohmmeter to measure resistance between White and Brown wires
3. Lift the float arm until the ohmmeter goes from 0 ohms to open circuit.  Measure the height of the float ball above the bench top.
4. Adjust the toothed wheel to add or subtract from the reserve volume as you desire.
5. Perform Step #3 again, noting the new height the float assumes when conductivity ceases -- higher above the bench for more reserve volume or lower to the bench for less reserve volume.
Offline John Lang
  • John Lang
Re: Fuel tank
« Reply #8 on: August 28, 2017, 04:10:55 PM »
Very clearly explained. Thank you, Robert.
  • Ottawa, ON Canada
Offline John Lang
  • John Lang
Re: Fuel tank
« Reply #9 on: August 28, 2017, 04:48:15 PM »
My toilet tank and I go way back. It has no cogwheel.
  • Ottawa, ON Canada
Re: Fuel tank
« Reply #10 on: August 28, 2017, 05:01:06 PM »
John go out and buy a BMW toilet tank they are equipped with a toothed wheel.  :2thumbup:
Offline White Dog
Re: Fuel tank
« Reply #11 on: August 31, 2017, 09:21:35 PM »
You go ahead and bend your float rod and report back what happens.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline John Lang
  • John Lang
Re: Fuel tank
« Reply #12 on: September 01, 2017, 06:56:17 AM »
Mine is working just fine. Hanes warns against bending the arm when removing the unit from the tank, so it is bendable. But, as RBM noted, why McGiver it when an adjuster is provided?
  • Ottawa, ON Canada
Offline White Dog
Re: Fuel tank
« Reply #13 on: September 01, 2017, 09:05:01 AM »
So why did you ask the question "Why not simply bend the float rod downward (if signalling too soon) or upward (otherwise)?[size=78%]" [/size][/size]if you already knew the answer?  Are you in Troll-Mode?[size=78%]
[/size]
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline John Lang
  • John Lang
Re: Fuel tank
« Reply #14 on: September 01, 2017, 09:15:19 AM »
No, it was an honest enquiry. I asked about bending the arm when someone mentioned the adjuster wheel is delicate and could be damaged. I thought it might also be necessary to remove it from the tank to get at it, requiring the sealing gasket to be replaced. The McGiver treatment seemed expedient.
  • Ottawa, ON Canada
Offline White Dog
Re: Fuel tank
« Reply #15 on: September 01, 2017, 09:23:02 AM »
Ok.  You are right about the delicacy.  I stripped the teeth off my original sending unit but with the new replacement I bought from a seller on this board, I was able to advance the gear wheel one cog to see if that helps.  So much for trying to adjust the unit while it is mounted in the tank.  Can't see, hand in awkward position, not to mention submerged in gasoline.  It is a crap shoot to R/R the unit each time an adjustment is made, but no one seems to say how much of an adjustment is needed, other than by trial and error.
I could put the old unit back in and put black tape on the dash panel light but it would look tacky.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
