Author Topic: Welding on a brick  (Read 4537 times)
Offline castaway12000
Welding on a brick
« on: July 02, 2017, 06:12:42 PM »
I'm about to do some farm fabrication.  Should I disconnect anything else besides the ECU and the battery?
  • California
  • 1985 k100
Re: Welding on a brick
« Reply #1 on: July 02, 2017, 06:26:16 PM »
Keep the welders earth lead as close as possible to where you are welding. Not sure what else.
« Reply #2 on: July 02, 2017, 07:35:13 PM »
Disconnect the ICU under the tank and possibly the gauge cluster as well.  Also ABS unit in the tail if you have one.
Offline whosyurdaddy
« Reply #3 on: July 03, 2017, 06:33:20 PM »
 I disconnected my battery ground only when I welded on mine with no ill effects
  • Central Indiana
  • 1991 K100RS SOLD
« Reply #4 on: July 03, 2017, 09:25:11 PM »
Disconnected the ECU, battery, and the lunch box and no problems.   Thanks again everyone!
  • California
  • 1985 k100
