TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Atabeach on June 27, 2026, 02:23:55 PM
Ok was running absolutely perfect, yesterday...she always backfired under deceleration but now on low rpm throttle. Starts right up, soon as the temps get up backfiring & stalling on low RPM. OK soooo I used the propane trick to check for leaks at the throttle bodies...no noticeable increase in RPM. Pressed the starter button, verrrry slight decrease in RPM. The fuel pump is new , Z hose new...checked for leaks in and around air box... next Im going to take out plugs and see how they look. any usual suspects Im missing? TIA
HALL SENSOR...
Verify that the battery positive clamp, the battery ground clamp and the battery ground cable attachment on the transmission are tight.
Click this link (https://motobrick.com/index.php?topic=11014.msg95717#msg95717) to the opening post of the Service Manual section here. Click on the link to Vogel's troubleshooting guide at the bottom of the opening post. Perform the tests of the throttle switch and the coolant temperature sensor explained on pp. 25–29. Let us know the results.
Thanks Laitch, So I checked the Grounds and Positive terminals and then spent about an hour reviewing Vogels detailed post. Very informative, thanks.
1) The post referenced non start issue regarding throttle switch. Page 7/8 I did not see how to test it. For historical purposes the bike is an 85 and …backfires. Maybe It should be changed. Please advise.
2) I did not see how to test coolant temperature sensor either. Please let me know the ohm value or how to test the unit ….
I did discover an oil leak coming from the bottom of the air box ( photo 1)
Thanks again.
The photo of the air box in your post is of the intake air system on an 4-valve engine, not a 2-valve engine as should be in an '85 K100. The 2-valve air box that connects to the throttle bodies is pictured below. What's going on, Florida Man? :laughing4-giggles:
(https://motobrick.com/gallery/4/1601-270626221937.png)
(https://motobrick.com/gallery/4/1601-270626222121.png)
Ok soooo no internal hose, Check!
Can i assume since the fan clicked on the coolant sensor is good?...or is there a different sensor?
In Vogles post he stated that the hall sensor seemed to act up when heated...we are in Florida.
Check? None of that assembly belongs on a 2-valve K100 Brick so what's a photo of it doing in a thread about the performance of a 2V Brick engine? I don't know what you've got going down there in the steamy sub-tropics. Will you offer a comprehensible explanation? My next dose of coffee isn't until after 8am tomorrow.
177381
The photo was posted in error, I will attempt to remove it.
Is this a photo of one of your Brick's throttle bodies? If it is, what is the blue linear object in it?
Throttle body nearest to Z hose ...Blue object is pointer to the area of oil leak...
The 2V air box has throttle body intake pipes molded into it as can be seen in previous post #3. There are no joints in the box’s construction to leak; it would need to be cracked. Leaking is unlikely because crankcase blow-by is received into the air box from the z-tube then mixed with air being drawn from the box through the throttle bodies. Oil shouldn’t be "flowing" anywhere in the air box to create a leak. Oil should be in blow-by vapor that enters the throttle bodies to then be ignited in the cylinders. It’s possible that the z-tube is leaking where it is attached causing some oil vapor to condense on the outside of the air box instead of all oil vapor entering the throttle bodies. If the intake rubber hoses were leaking, that would have been evident in your propane test.
Closer inspection is needed.
Further inspection revealed some oil at the top of Z hose so that is probably where the oil is coming from….obviously not the reason for the bike running poorly.
The post by Vogel specifically mentioned running rough when bike is hot would point to the Hall sensor. I tried to remove it from the bike to test it but the 5 pin connector crumpled miserably in my hand. I need to change it anyway so hopefully that was the issue.
It was the Hall sensor. Vogel had it right...when the bike fails when HOT....
103123
Honeywell S7C - 2AV54 a discontinued parts from long long ago. Try Chen Yang CYHME56 Hall Vane Sensor. High temp leads may have to be added. Current price 1-10 $5.00.
https://www.chenyang-gmbh.com/en/hall-effect-vane-sensor-cyhme56c-output-npn-oc-power-supply-4.5-v-24-v-dc-alternative-for-2av54-2av16a-2av51a-2av56-honeywell.html (https://www.chenyang-gmbh.com/en/hall-effect-vane-sensor-cyhme56c-output-npn-oc-power-supply-4.5-v-24-v-dc-alternative-for-2av54-2av16a-2av51a-2av56-honeywell.html)
Gentlemen…the issue is not resolved. Ok a few rides and the bike fairly warm no problems…Then a nice decent ride…the problem still exists. Backfiring , only runs at 3500 rpm. What are the odds of another bad hall sensor?
Test the coolant temperature sensor as was recommended in Reply #1. It's a simple test.
The multimeter is set to Ω. The ignition switch is Off. The ground lead touches contact #1 of the fuel injection plug, the positive probe contacts pin #10. There's a photo of the plug with the contacts numbered in Vogel's a few pages after the Hall Sensor section. At ambient temperature the multimeter should read approximately 2.5KΩ.
If the values are close to that number, start the engine and point a thin stream of propane at the joint of the z-tube with the air box as shown in your photo of the oil leak. If the revs change during spraying, that's one problem uncovered. If okay, move on.
Here's a way to test the hall sensors without removing them.
This short video only shows the test results for one output, the test should be done for both, the brown wire and the orange wire.
https://youtube.com/shorts/P3X0zvDY6Vw?si=V3UK2QuetQEQQroF (https://youtube.com/shorts/P3X0zvDY6Vw?si=V3UK2QuetQEQQroF)
If your brick is the earlier model of 1985, the coils aren't the best. You could use a timing gun to check for a good signal from the coils to the spark plugs, or even look at them for cracks. In your troubleshooting guide, there are also tests for the coils.
Thanks Daveson, At this point I will in this order
1) test temperature sensor & propane around z tube , thanks Laitch!
2) test coils ( I think I have spares from box of stuff )
3) remove the used hall sensor I bought and bench test
Thanks, I’ll post the results
Meanwhile in the garage… another barn find. $500, plus handling😳
That's one of the rare BMW unicycles. Great find!
Bike cold, starts right up but the hesitation is apparent right away...
1) Quick look at spark plug wires no signs or arcing...Coils no cracks , will bench test shortly.
2) test value of female pin 10 to ground is 1.5...this is below 2.5! I will be replacing temperature sensor either way....
3) bench test hall sensor..pins 2 & 5 ....all appears good.
Q Should I apply heat ( blow dryer ) to hall sensor?
Q Is the value of the temperature sensor @ 1.5 so low as to keep the bike from running?...TIA
Don't have my books at the moment so limiting my replies.
Give the electrical plugs a good clean with the help of some electrical contact cleaner.
If the situation is still that the problem is much worse when the engine gets warm, this would be the best time to do tests, as it doesn't have enough time to cool down compared with bench testing. Also it could pass a static bench test, but might not pass a dynamic test while cranking.
Here's another, even quicker test. The test in this twelve second video will verify if the Hall sensor is sending a pulsing signal to the computer, and also verify if the computer is sending a pulsing signal to the coil. Then repeat the test for the other coil. This could be done with the fuse for the fuel pump removed.
https://youtube.com/shorts/5VrtFtr07-4?si=M8VIfew8xUk24JT2
Another video, four seconds long, which should verify that the Hall sensor is sending a pulsing signal to the computer, and that the computer is sending a pulsing signal to the injectors.
https://youtube.com/shorts/Hqttqo-y0xg?si=H2fvwdDZ2N2eMD-G
Daveson, thanks for the 2 videos. … In the 12 second video the probe enters the boot, does the wire lead go to ground… I want to be sure. Thanks
If the value at the temp sensor was at 1.5KΩ when the engine was cold, that wouldn't be likely to activate enough fuel for a good start.
The test light clamp is attached to battery positive. I posted more details in the comments section, I probably should have posted it in the description. Actually I should have shown it on the video, it would have only been a few extra seconds.
The problem is occurring when the bike is cool also. I took the bike out today and it ran fine for a while.
Some observations and my thought process:
When the problem occurs the front exhaust pipe tube and the rearmost pipe are significantly cooler. Using an infrared sensor confirms this….They are not firing as they should. I believe this is cylinder 1 & 4
Tests:
when the problem is occurring… I will use a test lamp at the back of Hall sensor connection , pin 2 and or 5 to negative terminal…).
When the problem is occurring I will test the black wire clip on coil 1 & 4 …to a positive terminal. Depending on results…
I will then bench test coil or swap them with extras I have.
Please let me know if this makes sense or if I am missing something
TIA
Yep, that makes sense.
We don't know the quality of your spare coils. One option, swap the coils on your bike, if the problem transfers to cylinders two and three, it's probably a bad coil.
On my 1984 brick, both coils had cracked cases, but the cracks could only be seen after removing the coils. They both had open circuits, so that would probably be a quicker test than swapping them.
Notice in the Hall sensor video that the test wire is clamped to the battery negative post, not the positive. It is tricky. The pulsing signal from the Hall sensor is positive, but the pulsing signal from the computer is negative.
To muddy the waters even more, they came up with a real doozy. I would have loved to be in the meeting room when they designed this one, but I can imagine how it went. Someone in the meeting says "Hey, the two positive signals from the hall sensors, let's have an orange wire for one, and a brown wire for the other, because every other brown wire on the bike is negative" They all started laughing, then someone says "good one Fritz, let's go with that"
so the coils were tested on bike and then removed..bench tested...2.6 ohms
COILS GOOD.
The hall sensor was bench tested...good..UNTIL
The hall sensor connection was tested ON BIKE...( 12 SECOND VIDEO ) .Orange to lamp to negative terminal..No light! Same with Brown.
WTF! the bike starts!
Too early to start the party.
COILS GOOD.
What's the value at the secondary terminals?
It's good to know I'm not the only one who has WTF moments.
When I found out that both coils on my brick were open circuit, I said to myself "WTF, but the bike starts and runs" So I said it again, I said "Daveson, what the fuck"
It was very difficult to start, but when warm it would start easy and run well.
Here's my guess, which may apply in your case as well. I guess there was a crack somewhere along the circuit. Depending on the location of the crack, sometimes the crack gets larger when warm, sometimes it gets smaller. The electricity can jump the gap, as it does at the spark plug. The Hall sensor problem could be opposite to the coil problem I had, therefore when it gets warm, the gap gets bigger, and it struggles to cope. I think the situation with my coils was very unusual, because every other time I've heard about coil problems, they failed when they got warm.
Maybe it's just the hall sensor plug. I would repeat the test on both sides of the plug. If the test result is good on the input side of the plug, then you need a new plug, because the test result was a fail on the output side.
Of course you aren't; we even have an emoji here for the occasion. :thisplacewhack
W-T-F..
Laitch…OL reading across both secondary spark plug terminals in BOTH coils. I used two different multi meters. 2.8 across primary. The bike starts and runs.
Observations, With the bike running:
Test light from primary coil to ground illuminated test light but slowed idle. (Probably normal)
Test light from hall sensor female pins ( back of clip ) 2 & 5 to negative terminal did not illuminate small led or test lamp…
The fan clicks on normally when hot.
Continuity between hall sensor disk & wires / wire pins are good.
Not sure where FEMALE pins lead…please advise! I want to test continuity.
Question: I have 3 K 75 coils. Can I safely remove one primary wire & spark plug wire …and attach to one of the K75 coils?
Laitch…OL reading across both secondary spark plug terminals in BOTH coils. . . . I have 3 K 75 coils. Can I safely remove one primary wire & spark plug wire …and attach to one of the K75 coils?
:thisplacewhack
Wow, I always thought of that as meaning "nothing to see here" or "boring"
I hope I haven't put any noses out of joint in the past, due to my misinterpretation of that one.
It was labeled by its creator (or enabler), "Thisplaceiswhack". :laughing4-giggles:
But was the light pulsing? I suppose it was. It's more rapid at idle than while cranking, so more difficult to see a pulsing.
Test light from hall sensor female pins ( back of clip ) 2 & 5 to positive terminal did not illuminate small led or test lamp…
With positive on both sides of the test light, the light will remain off.
ALERT! This morning started bike…ran rough ….TEST LIGHT from pin 2 & or 5 to positive shut bike IMMEDIATELY …test lamp does NOT illuminate
...the light...
Again, with positive on both sides of the test light, the light will remain off. This test provides constant power to the hall sensor, so the pulsing signal is lost, therefore the engine stops.
Don't test continuity because your multimeter supplies power to do this, Hall sensors are very sensitive and can easily be damaged. This is probably why Bert's guide warns us not to use an Ohmmeter for Hall sensor tests.
The Hall sensor signals go to the ignition control unit.
I wouldn't, K75 coils are different.
One safe test would be to swap the coils to see if the problem transfers to the other two cylinders.
Daveson, I wrote it incorrectly the lead from back of hall sensor is to the negative side. Light does NOT illuminate…with ignition on or while cranking. Further, I bench tested Hall sensor again. 👍🏻
….both coils seem to provide good spark. The plugs are wet so for now I am hoping the new Bosch temperature sensor will solve problem.
Daveson, thanks again
My new addition is up and running ( see photo )
…another barn find 🙄🙄🙄
Soooo A new Temperature sensor arrived today....still running poorly.
I did notice today that the voltage ( 12.4 at idle ) never climbed above 12.9 when increasing RPMs. The battery is new and tests "good" on my battery tester even under "Load"
What is the battery voltage when the ignition switch is Off?
12.5 Volts. With some lights off she climbs to 13.2ish
I tested the TPS with test lamp and multimeter...zero ohms from pin 1 & 2....test lamp on until I turn the throttle.
Pressing the starter button at idle bogs the bike down instantly.
What is the battery voltage when the ignition switch is Off?12.5 Volts. With some lights off she climbs to 13.2ish
Your response to my query seems to indicate that some lights are on when the ignition switch is turned to Off. Is that the case?
No…12.5 volts ignition off. 13.2 with the bike, running at about 4K…accessory lights off
The battery seems weak and so does the alternator charging current. Has the battery light in the instrument cluster been intermittently flickering or faintly glowing when riding or idling?
I had to replace the alternator on my '85 K a few months ago and the new one read 14.0 volts at idle.
Frank
No. The alternator goes out and remains out unless she is about to stall. Agreed..13 volts low but should run the bike.
Please update.
Does the Brick start reliably? Does it ever start and idle until shut off?
Does it idle smoothly?
Can it be ridden any distance at all without conking out?
She stars reliably, one shot. Idles rather smoothly…at 1k …anything below 1k she will stop running. When I hit gas she backfires and surges. She surges and cuts out when ridden. She constantly blows smoke.
My thinking:
Although 13 v is plenty…I’m going to change alternator as it is probably getting tired.
I have a used fuel regulator from a k75…I’ll change it
While the airbox is out I will bench test the airflow meter.
….let me know if that makes any sense.
Is the airbox out now? If it isn't, why is it being removed?
The fuel regulator is behind it…am I using the wrong terminology again.? The black box thingy that holds the air filter….
Yes that is correct, the airbox and yes, he fuel pressure regulator is behind it.
Is something wrong with the fuel pressure regulator, or is it to be part of a feng shui reorganization?
Am I mistaken to believe a faulty fuel regulator could cause a rich running condition? The temperature sender , TPS and coils seem to be fine. I’m just going with process of elimination. Does anyone think 13 volts is not enough to run the ignition system. Please advise.
I don't believe an alternator outputting 13V while the engine is running is capable of producing engine performance reliably.
Certainly, a fuel pressure regulator be a cause of over-fueling, but so can a clogged fuel return line, a faulty fuel pump or a faulty fuel injection control unit, not to mention the air flow meter which can be tested in place rather than on a bench. Repair using the process of elimination can be too costly for many of us; that's why there's all the testing; however, replacing parts also can eventually improve performance, if the defective part—or parts—eventually are replaced. That seems to be the diagnostic strategy with this Brick. AI can make a great companion for that.
Thanks Laitch, I will take your advice and change the alternator….and move forward from there if there is no improvement….further, I was mistaken. I thought the alternator voltage at 13 would have been more than enough.
This model 1985 has a 33 amp alternator. Would anyone recommend a rebuild kit? Otherwise I am buying used off of Flea bay....
That isn't my advice.
The battery reading should be ≈13.5V to 14.5V with the engine running. Resting voltage should be 12.6V or above. Why do your battery's figures differ? My advice is to determine the root of each condition one step at a time. Why is your Brick's battery at 12.5V instead of within the optimal range. One case here where the battery wasn't holding a charge was caused by the alternator's cable connection to the battery being loose at the alternator side. Another case involved a bad diode.
All electrical connectors and ground connections of a 40 year-old Brick are first suspects when engine performance is erratic. The components themselves are the next suspects.
Laitch:
The battery and grounds were removed cleaned and reinstalled…reply 1 ( Bike was sitting for a decade and all electrical connections were removed& cleaned.)
The battery…at 12.5 was tested using my battery load tester…showed good…re- assess as needed, 4 months old…
…The bike always seemed to charge and start right up. I never thought to test the charging system, when I did I still thought 13 Volts was sufficient to run…ignition. Guess it may not be.
So....now, I removed and bench tested alternator ( to clean all brushes & contact areas also )
Turns out she is tired. Ohms across the two brass armature rings should be 2.5….they read 5
Changing the original 40 year old alternator makes sense…as did the temperature sender ( ohm reading not perfect) and hall sensor….not big ticket items.
The coils and wires checked out ok and were not replaced.
I am following a logical order here not haphazardly changing stuff.
This is a $750 barn find…so I was expecting some costs….It still has the original fan!
Thanks for your …..help. 😳😳
So the alternator was changed I am getting a solid 13.7 at around 2500 rpms. Battery was swapped with my other bike...no difference. I changed out the fuel regulator (used) no improvement....The bike always starts right up and idles smoothly at 12/1300 rpm. It backfires when revved or put under load by riding. It smokes at all rpms and all the plugs are still wet with gasoline.
I wonder if your coolant temp sensor is faulty, causing the ecu to think the engine is too cold therefore pumping more fuel than needed? I don't recall but did you adjust your bleed screws to have a in-sinq throttle body?
The temperature sensor was changed. I have not adjusted the screws because the bike was running fine…This happened suddenly. Thanks
tps reset?
The throttle position sensor was tested. If I remember correctly it clicks and you essentially test for continuity..Please post the procedure if that is incorrect. Thanks.
Laitch had mentioned the air flow meter. I don’t know how to test this while component is on bike.
Lastly….mine is an early 85 and has this vacuum switch…( see photo ) ...anyone know whether it may be the problem….or how to test it ?
COILS GOOD.OL reading across both secondary spark plug terminals in BOTH coils.
You've only done half the coil test—the input side. OL is not an acceptable value. Either your multimeters have been set too high and are not sensitive enough to make a reading, the test leads are not contacting the terminals, the leads are not well connected to the instruments or the multimeters themselves are not suited for the application.
Ok soooo I purchased a new multimeter. Set to 20k ..,My k75 coils test around 10k with this and my old meter…My k100 O/L. Both coils. Across both spark plug towers. Tried it with plug wires on too… the bike starts and runs so I’m doing something wrong. It can’t be O/L.
Congratulations on your new multimeter!
Based on your comparison with the K75, it's possible the coil can only supply enough current to allow the engine to idle. When the demand on the engine goes beyond an idle, high resistance within the coil cannot supply enough energy to meet it.
Do you have a spare coil pack or two?
I have 3 coils from a k75. Any ideas
Laitch...Reasoning 101: this happened suddenly. The bike was running flawlessly....Could BOTH coils get tired at the same time? ...or Could...the $30 multimeter be off?
The coils and wires are 40 years old...changing them is not a BAD idea. TIA
I've got a couple of sets of coils I recently pull from 2 K1100 tear-downs. I can measure them tomorrow and see what they read, if that would help.
Scott that would help. My inkling is what Laitch suggested…they may be tired. They are 40 years old…Email me if you are willing to sell a set..Thanks
Ok, so I didn't wait till tomorrow... lol
I have a set that is an early '93 and a set that is late '95.
93 set:
13.23 kohms on the plug side 0.7 ohms on the ecu side
12.89 kohms 0.7 ohms
95 set:
12.85 kohms on the plug side 0.6 ohms on the ecu side
12.87 kohms 0.6 ohms
I could sell you a set, however looking at your picture I don't think they would be a direct fit for the older k100. The plug wire set is different style as is the ECU connector is not a spade connection on the 1100's.
Scott that would help. My inkling is what Laitch suggested…they may be tired. They are 40 years old . . .
According to the photo in your Barn Find thread, the engine case reads 1984—42 years. It's likely the engine was completely assembled that year. The coils in the engines of the early models like that are notorious for becoming unreliable. That's well documented on this site and elsewhere. Later in production—late '85 or in '86—the coils were replaced by coils much more reliable. They could be identified by the orange tops of the secondary terminal towers.
The resistance of the K1100 coils is around 70% less than the primary resistance of the K1002V coils. Figures below are from the LE Jetronic Testing for K Models manual downloadable here.
My understanding is this particular difference can possibly lead to the overheating and failure of the ignition control unit. The failure wouldn't necessarily be instantaneous but definitely could be inconvenient or even dangerous depending upon where it happens. Maybe somebody who has done that swap can chime in. If not, you could be the pioneer! icon_cheers
They're pigs-in-a-poke but there for the buying. This is what the later generation coils look like via eBay (https://www.ebay.com/itm/267743293107?_skw=bmw+k100+coils&itmmeta=01KZJACG3HC158Z4692KEPN359&hash=item3e56be6eb3:g:XEIAAeSw46tqa4xS&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xDg2AD2A6eEDgPtV9aM0mWNSFXccL%2BjSuvltDzaeIb5nFeLQX4FReo4a%2BtCoYq4NxB6TOfDuizfM7xTvL5yuL4k8DKBxIUjYf359Qw7kuavg7gIqakakz4%2BJZ0imvfhOwq2KPF5SXTqsSEnMvyns1Gq%2FiHSI%2Bsi9D8I8oxTYFfx1fwwigzpaHL0FDhBQg%2FPrdqbDD%2F%2B6U0ae3g1GBQAQ0az%2BYccgBEUTDw8LvNrv2UozH1PrmV71mYZydUBMkgI1aU%3D%7Ctkp%3ABk9SR_qBssr8Zw) right now.
(https://motobrick.com/gallery/4/1601-080826235504.png)
Thanks, Scott… Laitch, I’ll get the orange cap ones on eBay. This will take a week or so …
in the meantime can anyone post the process to check the air flow meter…
Lastly, there is a fuel vacuum switch near the fuel regulator. It was eliminated in later models. What does it do? Should I leave it be?
Its effect is up for debate, except at BMW. It was removed because it took extra material and labor cost but it effects were debatable, even in Germany. The Removers won the debate. Leave it alone as an original production artifact, or remove the hoses and cap the source points of the hoses then remove the vacuum switch to give to your favorite grandchild to use as a mobile over its crib, or as a crackpipe in its bedroom.
One possibility is that one coil was working well and the other coil was working, but not well. A crack could show an open circuit when tested with a multimeter, but the high current could jump the gap while running, which would be about zilch millimetres. It jumps a big gap at the spark plugs (one wasted) Now if the other coil fails, the problem becomes much worse.
I don't think the spark plug leads have been tested yet, that would be worth a look. Original leads from a K75 should not be used, they're different.
The air flow meter is dealt with in Bert's guide, which I think you have.
It's not a fuel vacuum switch, it's a vacuum switch. Check anyway the vacuum hose to the fuel pressure regulator, that it's not leaking, or kinked, or blocked, or partially blocked. Do these checks also for the hose to the vacuum switch.
Some people remove it because they notice no improvement in performance with it connected. With that reasoning you could remove a wheel nut and throw it in the bin, there would be no drop in performance but after a few years the disc might develop a warp. It might not warp either, but why bother second guessing the engineer's who designed it that way? It's not meant to improve performance, it's there to improve fuel economy, reduce pollution etc, mainly while cruising. They have put it there for a reason, so I think leave it connected.
At higher vacuum you want to advance the ignition timing because it takes longer for the detonation to complete in these situations. You can use an LED test light to check that it sends a signal to the ignition control unit, from memory I think it only sends a signal at part throttle. You could use a timing gun to check that the computer is altering the timing. I guess no one has done that yet on this forum. You could check the exhaust emissions at cruising, with the vacuum switch connected and compared with it plugged, but I'm guessing it would be a tiny difference.There might even be a drop in revs if it is plugged to remove the signal while cruising.
Some thoughts about why the vacuum switch was deleted, just guessing.
If we think about the carby days, we had a distributor with mechanical advance, vacuum advance, and points. These parts would wear out and become increasingly inaccurate over time and use, and often fail. The ideal gradual increase in advance required for increased RPM is not identical to the gradual change with the springs in the mechanical advance, but it was considered good enough at the time. So they weren't even accurate when new. Computers can use sensors with fewer parts that wear out, and can be programmed to provide the ideal amount of advance. A vacuum sensor was used for vacuum advance. Then it was realised that the computer can be programmed to provide the correct amount of vacuum advance without a vacuum sensor, due to the inputs it gets from the hall sensors.
BMW often made parts backwards compatible, in this example there would be no need to change the part number, anyone wanting to buy an ignition control unit would be supplied with the new version.
In later models with a motronic computer, it was realised that the fuel pressure regulator doesn't need vacuum assistance to reduce fuel consumption in high vacuum situations, again the computer already has enough inputs to predict the ideal amount of fuel required, and provides it according to its program.
So my venture into used coils:
the orange cap coils from flea bay; one good, the other O/L ….all plugs still wet with gasoline.
Placing spark against engine block, swapped good coil with bad , BOTH SHOWED GOOD SPARK, at all rpm’s.
New set is about $400 ( need an opinion here )
Another flea bay set bench tested O/L WTF? These came from running bikes?
All battery wires and grounds gone through ( AGAIN ) good 13.6 volts at 3000k, good 12.7 battery ( ignition off)
Lastly,
Air flow meter female pins…ohms tested well, door moves well. Changed with used one I had…same.
What am I missing? Bike starts and runs rich!
did you balance the tb and reset the tps?
So this happened suddenly, as if something went wrong. I have NOT balanced the throttle bodies since this event. The Throttle position sensor clicks. I also removed the clip and tested the contacts...seems fine but i will check again. Thanks for the input.
As demand and running time on a coil increases, resistance in its wires increases. If a wire or wires in the coil have a thin fractures the engine will run until the resistance in the defective wires increases causing an open circuit.
When testing, is the coil with the O/L always used for the same cylinders, or is its position swapped?
My suggestion is to contact the seller, show the meter reading and ask for a partial refund. If the seller doesn't offer refunds, eBay has a refund policy.
So I have swapped the coils and wires several times. Note: on the good coil … no matter the location , the spark plugs …. Are wet. I ran the bike till the fan clicked on. All 4 plugs wet. Bike starts right up and runs… constant smoke.
Let’s assume the coils are good. Air meter bench tested , door moves smoothly….changed! fuel regulator changed. One thing I have not done was go through the fuel system.
The pump, filter, all lines and injectors were purchased and installed NEW 3k ago.
… open for suggestions. I’m missing something.
Plugs can be wet when there is too much fuel, when the fuel is the right amount but there is not enough spark, when the fuel injectors seize open, when the fuel injection control unit is defective, when the ignition control unit is defective, when the hall sensors are defective, ignition timing is incorrectly set, when the airflow meter or its temperature sensor is defective, when the coils or their wiring have defects, when the coolant temperature sensor is defective, when the spark plugs are the incorrect type, or when the spark plug wire connection is the wrong type for the coil wire.
The current assertion seems to be that almost every critical part in the ignition system has either been replaced or passed testing. The assertion includes the observation that the plugs are giving a "healthy" spark, every part in the fuel tank is only ≈ 3000 miles old and the fuel pressure regulator has been replaced.
What is the fuel pressure in the line from the tank directly to a fuel pressure gauge? What is the fuel pressure if a T is fitted to the line from the tank to fuel rail and the pressure gauge is attached to the center leg of the T? What is the model number printed on the coolant temperature sensor? Where was the coolant temperature sensor purchased. Has continuity of both coolant sensor wires been verified?
I couldn't work with a multimeter that repeatedly gives unexpected O/L readings—e.g., O/L on a coil connection that is firing a "healthy" spark—until I understood why it was registering that measurement.
The upside of this situation is that you apparently have a high functioning R1100 to ride. icon_cheers It might be time to cruise down to Blowing Rocks and take a break. You've earned it.
Thanks Laitch, the only thing I haven’t done ( at least that I can think of ) is fuel pressure. I will test and update. The ignition module may be faulty but I want to be sure it is not an easy fix here. Thanks again.
Everytime you swap something, roughly, that will be another item of unknown quality.
Have you replaced spark plug leads with a K75?
With a K100, the high tension circuit jumps two spark plug gaps, one wasted. Original K75 leads have an air gap. The high tension circuit in a K75 only jumps one spark plug.
A K100 with K75 leads would mean that the high tension circuit would need to jump three air gaps.
I'm not home for a month so I can't post the part numbers for K75 spark plug leads. It might help if you post the numbers. Alternatively, spark plug leads with an air gap will measure O/L.
It's a bit of a long shot, but you have a K75, so I thought it might be worth mentioning.
I have not swapped the K 75 wires. For the record… when a “ swapped part” results in no change, I put the original part back. Unless it is new. I purchased used coil and wires from k 100 series bikes. Although the coils showed O/L ( 3 quality multi meters) repeatedly swapping proved fruitless. I’m goin to go through every wire and fuel line and electric clip. I’m missing something Thanks
Goodo, good procedure. Have you tested the resistance of the spark plug leads?
Yes 5 ohms on the shorter ones 8 on the longer. Thanks.
Ok, two coils are installed, if either of them test O/L, that's a test fail.
Understood. But reasoning would be those two coils would be dry. Not wet with fresh gasoline. Please confirm that reasoning
Your reasoning is good. I don't know your problem yet. I'm thinking a weak spark might not be good enough for combustion, that would lead to flooding. I should look back to see where you're at.
I'm thinking you have one good coil, and one test fail. Then only two cylinders should be wet. Then swap them to see if the problem follows the coil.
If the spark is erratic at all cylinders when one coil is good, to me that means the problem would be upstream of the coils.
Look at the videos I posted, they are very quick and easy tests to do, and will help to pinpoint the problem area.
I don't remember how to post the video, instead of the link, I might try again later.
Can you get your hands on a timing light with inductive pick-up? When you clamp the pick-up on the spark plug wire it'll flash with every spark. If it doesn't flash you have no spark...It's a way to test for spark with everything put together.
According to BMW's Testing for K Models manual, here's how to test spark plug to coil wires of a K100 2V model. Let us know the result.
(https://motobrick.com/gallery/4/1601-310826120308.png)
Really good information, Thanks….21 ohms at the coil that tested well. O/L at the coil that tested ….O/L …I am not changing anything until the coils show factory specs….i need 2 good coils before moving on.
I did re test the hall sensor by placing the bike in gear and spinning the wheels. 12 volts to 3.9 , alternatively.
The ignition module pins 1, 2 & 4 are providing power and ground to hall sensor.
If there are further tests at that module, let me know.
I tested continuity from pin 10 to thermostat sensor clip...Good. Thermostat : 1.7 from single pin to ground, 300 across pins. 1. 7 across pin 10 and 13.( ecu )
I will continue to continuity test… point to point anything accessible including re doing all grounds.
Thanks guys
Ignition control unit pin #2 provides power to the Hall sensors; pin #3 provides ground to the Hall sensors; pin #4 conducts electomagnetic interference from the Hall sensor cable shield to ground; pin #1 is the ignition control unit ground, at least that's the way I read it all.
The thermostat is a mechanical device that responds to heat in coolant to route coolant for optimal effect. It has no electronic input nor output nor clip.
The coolant temperature sensor is grounded by its threaded connection in the coolant standpipe that is connected to the engine block. One pin in the coolant temperature sensor activates the fan via a resistance signal to the temperature sensing relay, the other sends a signal to the fuel injection control unit to help govern fuel mixture. Measuring across coolant temperature sensor pins does not provide any useful information. A coolant temperature sensor from a 4V Brick won't work well at governing the fuel mixture. That was the basis of my query to find the source and model number of your replacement coolant temperature sensor.
It is possibly time to take that ride down to Blowing Rocks for a break until a coil that doesn't read O.L appears.
In fact, I think I'll try to get down there myself—between tropical storms—this month after I prep the Brick. :laughing1:
You are more than welcome…Bring your golf bag
My therapist cautions me not to have any type of club in my hands, and is even critical of my having a rolled-up umbrella. :idunno: Thankfully, I live in the age of Gore-Tex.
FINALLY! Ok sooo It was the leads to the coils. Apparently the wires got pinched against the frame and each other…just enough for continuity but maybe not enough to fire the coils. 2 sets of used coils ( both bad ) I ended up buying a full setup from K Parts Holland. $300 directly. So far so good! Thanks to all that helped.
