Author Topic: Fuel leaking where fuel rail and injector meet for making love  (Read 7097 times)
Offline Arredondo1
Got a chance to continue working on the 88 k75 and finally got my gas tank completely assembled and installed. Went to fire up the bike and gas leaked all over the place.Gas was coming out from where the fuel rail meets the injectors, I deduced that the injectors are either not sitting correctly or they are not "drinking" their prefered beverage. What steps should I take next? I looked here and my fuel rail doesnt have any clips.
http://www.bmw-k100rt-page.eu/manual/FuelOil/13_FuelLub.htm
Where can I find those clips and could that be the issue?
I know the injectors are new, as well as the o rings. I have the reciept for the injectors from the previous owner as well as the old injectors that were taken out. Maybe they were just mounted wrong?
  • Texas
  • 1988 K75C vin 138518, 1990 K100LT Vin 181145
Re: Fuel leaking where fuel rail and injector meet for making love
« Reply #1 on: June 14, 2017, 06:30:56 PM »
If you have run this engine, the clips are wherever you disconnected them from the injectors.
* K75 injector clamp, from MAX BMW parts fiche.png (29.65 kB . 514x224 - viewed 730 times)
 Otherwise, you'll need to buy some.
Offline Arredondo1
« Reply #2 on: June 14, 2017, 06:58:32 PM »
Never ran it, only assembled the tank since thats all that was missing when I bought it. This was someone else's project that I took over. Where do I purchase them? I cant seem to find them.
  • Texas
« Reply #3 on: June 14, 2017, 07:11:49 PM »
Where have you looked?
Offline Arredondo1
« Reply #4 on: June 14, 2017, 07:15:18 PM »
Been doing google searches, pretty sure Im not searching for the right keywords.
  • Texas
« Reply #5 on: June 14, 2017, 08:53:56 PM »
nearly any bmw dealer.   look up the part number on realoem.com or any dealer site.  buy from dealer or google the part number for other sources.
« Reply #6 on: June 14, 2017, 08:54:56 PM »
You can find them here for sure
Start by putting in your bikes model and year and the last six digits of the VIN
That way you will be fairly certain any parts are the right ones for your bike
http://www.maxbmwmotorcycles.com/fiche/fiche.aspx
This is the part number btw - 13 53 1 274 729 - seems to be used on pretty much every K bike
Offline Arredondo1
« Reply #7 on: June 14, 2017, 10:40:45 PM »
Ok thankz guys, I'll google the part number.
  • Texas
Offline Arredondo1
« Reply #9 on: June 28, 2017, 11:17:44 PM »
Ok i forgot to post an update, clips went in fine and injector 2 and 3 no longer leak, however injector 1 still has a tiny leak. The injectors came with brand new o rings, maybe that injector had a bad o ring? If its the rail, how should I go about checking the fuel rail for this tiny leak? Or more importantly what ways are there to seal the fuel rail?
  • Texas
« Reply #10 on: June 29, 2017, 06:43:20 AM »
Don't go off the rails with diagnosis. Reinstall injector #1. The slightest application of lubricant applied on the o-ring might help it seat correctly—silicone grease, WD-40, motor oil, etc. You name it; it either has been recommended or condemned for use on injector o-rings.  :giggles
