Author Topic: ABS wiring loom destroyed bike won't start.  (Read 5512 times)
Offline kdicke
  • 1989 K100rs
« on: June 14, 2017, 03:43:08 PM »
My wiring loom for abs ripped apart by tire, and now the bike won't start. Would like to know what options I have
Sent from my Pixel XL using Tapatalk
  • Los Angeles
  • 1989 k100rs
1989 K100rs
Re: ABS wiring loom destroyed bike won't start.
« Reply #1 on: June 14, 2017, 03:48:39 PM »
more info... does your horn work...
« Reply #2 on: June 14, 2017, 04:29:42 PM »
yes..define "does not start"
no power at all?
lights on starter no workee?
starter turns over, no ignition?
that kind of damage probably shorted a few things out and blew a fuse or two.  have you checked all the fuses?  go into the relay box and pull the two abs relays to cut power to some of the abs wires.
some of those destroyed wires could still be shorting.  go through them all and fix, or cut the entire connector off cleanly a inch or to up from the damage.
« Reply #3 on: June 14, 2017, 04:40:32 PM »
i bet sinner73 has a spare abs1 connector... he is in the greater marina del ray area...
he could proally tune your carbs too...
Offline kdicke
  • 1989 K100rs
« Reply #4 on: June 14, 2017, 06:36:27 PM »
I guess my question is, if I cut off the wiring loom, will the bike start? Or does the connector complete a circuit. My abs didn't work anyhow. So, I'm weighing out my options to cut it off or splice the entire loom and hide the connector, and thank you for your responses.
  • Los Angeles
  • 1989 k100rs
1989 K100rs
« Reply #5 on: June 14, 2017, 09:02:19 PM »
LOL!
« Reply #6 on: June 14, 2017, 09:03:29 PM »
bike will run fine with the abs box unplugged, or cut out.
