Author Topic: Possible Sprag?  (Read 6469 times)
Offline smith913
Possible Sprag?
« on: June 13, 2017, 12:53:51 PM »
I ran into an issue after changing my oil.  The starter spins and that is all.  The fuel pump is active and all lights work.  I am worried that it is a sprag.  I have tried the solution where you spray cleaner in the small hole on the sprag and the same issue persists.  Push starting is almost successful, but never fully starts.  I have a slight hill in the parking lot i use and start pushing it in neutral then once up to speed i pop it into 2nd and press the starter button while releasing the clutch.  I get some sprag activation, but never for long and not enough to get the bike going.
I have tried a charged battery, a new battery but to no avail.
I used mobil 1 15w-50 on the oil change
I am starting to think it is the starter as i did a rebuild, but im pretty sure reassembled it correctly.
Has anyone experienced any issue like this?
Thanks,
Alex
  • Alexandria, VA
  • 1985 K100RT
Offline wally.fisher
Re: Possible Sprag?
« Reply #1 on: June 13, 2017, 02:27:23 PM »
Thanks,
Alex
You might have assembled the starter motor brush plate wrong way round, it's easy to do and many have. Google the reassembly for correct method
Offline mr_haut
Re: Possible Sprag?
« Reply #2 on: June 13, 2017, 02:45:48 PM »
When stationary, does the starter then activate at all. Can you hear it spin?
Sent from my Nexus 5X using Tapatalk
Offline smith913
Re: Possible Sprag?
« Reply #3 on: June 13, 2017, 02:50:47 PM »
@wally.fisher
Thats a good call, I will check that out after work or whenever I have time
@mr_haut
Yes the starter does spin when stationary.  you can definitely hear it
  • Alexandria, VA
  • 1985 K100RT
Offline bizzaro
  • co pilot
Re: Possible Sprag?
« Reply #4 on: June 14, 2017, 11:40:43 AM »
Before you take it all apart again, it may be worth trying to "back spin" the engine and starter?  Roll the bike backwards in gear a few times. It may be enough to "wake up" the sprague if the brushes are in correctly? Good luck.
  • Vermont
See Ya in the Twisties,
 Bizz
Offline thecableguy
Re: Possible Sprag?
« Reply #5 on: June 14, 2017, 12:05:47 PM »
A weak starter can make the sprag seem bad if it doesn't spin quickly enough or with enough power to get the sprag to lock up.  I know, it happened to me.
I take it you are hearing the sprag's blood-curdling squeal when you say the starter spins, and are not just hearing the starter motor spinning like it would on the bench with power applied?
Jim
  • Madison, WI USA
  • 86 K100RT - Brünhild
Offline smith913
Re: Possible Sprag?
« Reply #6 on: June 15, 2017, 06:31:05 PM »
It sounds like it is just the starter spinning. I dont hear anything coming from the sprag area
  • Alexandria, VA
  • 1985 K100RT
Re: Possible Sprag?
« Reply #7 on: June 15, 2017, 06:58:25 PM »
If you can get it started by push starting then do the Rislone or diesel oil flush treatment. You know about that, right?
It is suspicious that it won't start after a starter rebuild. Was it starting before the rebuild?
  • 1995 K75 89,000 miles
Offline smith913
Re: Possible Sprag?
« Reply #8 on: June 15, 2017, 07:03:53 PM »
I did some rislone but i was under the impression you had to get it spinning for it to help. As of now the rislone didnt help. I am currently rebuilding the starter again and triple checking my work. Hopefully i just had sloppy work.
I did give the starter a tap and noticed a drop in power, which led to the third rebuild. Im thinking i have an issue with the starter and grounding or load shed? Am i just spouting nonsense?
  • Alexandria, VA
  • 1985 K100RT
Offline smith913
Re: Possible Sprag?
« Reply #9 on: June 15, 2017, 07:14:56 PM »
That you all for the advice. Turns out i simply cannot rebuild a starter properly the first or second times. Im getting all the good noises now!  Too bad the battery died during the starting attempts.  Off to the charger :musicboohoo:
  • Alexandria, VA
  • 1985 K100RT
Re: Possible Sprag?
« Reply #10 on: June 15, 2017, 07:16:12 PM »
Describing your mistake will help others.
Offline smith913
Re: Possible Sprag?
« Reply #11 on: June 15, 2017, 07:39:58 PM »
The main magnetized cylinder was put on backwards
  • Alexandria, VA
  • 1985 K100RT
