Author Topic: Turn Signals Illuminate - No Flash  (Read 5790 times)
Offline K75Slark
  • Das Fliegen Ziegel!
« on: June 12, 2017, 10:48:50 PM »
The turn signals illuminate but don't flash on my '92 K75. I'll double check the fuses tomorrow, but they looked fine tonight.
The bike is running great; no other issues.
Any ideas?
'92 K75-Midnight Blue-~76k
Offline Sinner73
Re: Turn Signals Illuminate - No Flash
« Reply #1 on: June 12, 2017, 11:28:11 PM »
Sounds like the relay
  • Los Angeles ca
  • 88 k75 98 soft tail custom drz 400
« Reply #2 on: June 13, 2017, 12:47:08 AM »
This is a K100; your layout is similar, K75Slark.
* Flasher relay.jpg (37.15 kB . 506x266 - viewed 455 times)
Offline K75Slark
« Reply #3 on: June 13, 2017, 11:10:33 AM »
Thanks, guys. I'll give it a whack and try to unstick it tonight.
If it's toast, I'll go LED for my turn signals. Investing in dodgy relays is already a bridge too far away with the starter relay.
Offline kdicke
  • 1989 K100rs
« Reply #4 on: June 15, 2017, 11:34:05 AM »
Any ideas?
If I'm not mistaken there's relay that makes turn signal blinks, although rare they do sometime burn out.
Sent from my Pixel XL using Tapatalk
  • Los Angeles
  • 1989 k100rs
1989 K100rs
« Reply #5 on: June 15, 2017, 12:38:42 PM »
looks like you are searching for an exuse to do led's...(don't they need a relay too?)
but...the TS relays are not really "dodgy".  the originals lasted 20 years.   they are cheap and easy to replace.  common part you can get at local autoparts store for about $10.
Offline K75Slark
« Reply #6 on: June 15, 2017, 01:36:38 PM »
mlytle, I can pull apart the flasher unit and replace the relays?
That would make this a much easier project.
