Author Topic: K100 rear Wheel / Rim converting  (Read 4373 times)
Offline lumpus
« on: June 08, 2017, 01:56:36 AM »
Hi together!
I'm a little frustrated. I read in this and other forums that it is no problem to adapt a K1150 wheel to the K100. (ok, perhaps with an adapter..)
Now I got one with number 2 331 357 ....
First Problem is, the casted bolts for the break disc. I have to cut it off....
But there is also big difference in the offset of ~17.5mm. Which means that I have to mill off 17.5mm on a lathe.
Do I have the wrong wheel?
Thanks.
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
Re: K100 rear Wheel / Rim converting
« Reply #1 on: June 08, 2017, 02:49:53 AM »
Might help?  http://www.largiader.com/parts/wheels.html
Offline lumpus
« Reply #2 on: June 08, 2017, 05:25:16 AM »
Thanks Martin,
I know this table. My wheel is listed below, but it doesn't fit without massive modification. I'm not sure if I should do that. The easier way would be to use an other wheel.
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
Offline lumpus
« Reply #3 on: June 09, 2017, 01:24:05 AM »
Did anybody put a K1200 Rim on the K100? Is there any modification necessary? Spacer?
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
