Author Topic: Tail light issue  (Read 3483 times)
Offline castaway12000
Tail light issue
« on: June 04, 2017, 08:05:26 PM »
replacig OEM with after market lights
Brake light works, and the front parking light works kind of.... it works with a LeD but not a regular light
I tried to just run a jumper wire from the headlight to the running light at the rear but when I do that the aftermarket light just lights up full and the brakes don't do anything to the light
If I don't run the jumper to the running light portion of the after market light the brake lights work good
When I plug the OEM back in the brake lights work but the tail light still does not work
I do not have 12vdc at the pin (g/bulk) for the tail light
I'm lost
  • California
  • 1985 k100
Re: Tail light issue
« Reply #1 on: June 04, 2017, 10:12:32 PM »
I'm lost
I'm lost, too. Please explain exactly which bulbs are being replaced and what type and wattage of bulbs are replacing them, how many new assemblies you're installing and where they are located, and the expected function of the new arrangement.
« Reply #2 on: June 04, 2017, 11:45:45 PM »
The new arrangement is a single light with three wires.  One for brake one for running and one for ground
Mounted off the back using the OEM plug.  It's a model I got off amazon.   I also tried a different light with the same configuration.
There is no power at the grey and black wire that feeds the running lights.
When I plug the original tail lights back in... it doesn't work either but I can get the bike warning light on the lunch box/speedo to go off as Normal
I might just run micro running lights mounted in the brake from the headlight power
And mourn seperate brake lights
  • California
  • 1985 k100
