Author Topic: Replacing crazed glass on K100RS temp gauge  (Read 5004 times)
Offline champ7fc
« on: May 30, 2017, 07:33:41 PM »
I recently purchased a 1985 K100RS. The goal is to take it apart, replace items that will require replacement and refurbish those that can be. The coolant temp gauge glass is severely crazed, has anyone here ever replaced the glass on the instrument and if so how? I did look through the archive but found nothing.
  • Staffordville, Connecticut
  • 1987 K75S, 1985K100RS
Offline bmwpyro
Re: Replacing crazed glass on K100RS temp gauge
« Reply #1 on: May 30, 2017, 10:49:40 PM »
check this link out on how... and you can get lens on fleab*y
glass or plastic not sure which is better tho. both have pros and cons.
one thing to note: pls make sure to measure the diameter of the lens after you take it out to know what to order/make.
  • Azusa, CA
  • 1985 K100RS, 1990 K75S
Always Learning...
Always something new to learn about riding and Kbikes...
"Viam inveniam aut faciam"
Offline bmwpyro
« Reply #2 on: May 30, 2017, 11:18:37 PM »
That link doesn't work. Try again.
fixed. Thanks Laitch.
  • Azusa, CA
Always Learning...
« Reply #3 on: May 30, 2017, 11:27:19 PM »
That's a good find and should give champ some inspiration.  :2thumbup:
Offline champ7fc
« Reply #4 on: May 31, 2017, 09:28:34 PM »
Thank you all for the info and the links. I will measure the gauge tomorrow and get to work.
