Author Topic: Front wheel hop feeling????  (Read 39850 times)
Offline TommyT
  • New Brick Owner
« on: May 27, 2017, 12:19:14 PM »
I have a 1990 K75s with 45k+ miles. I have had the bike for 300+ miles. Right after I got it, I replaced the 12 years+ old tires with new Michelin V rated tires. At 35 to 45 I feel a hop in the front, it is worst around 45 and from there disappears to "almost" smooth over 50 mph. I had the wheel and it's balance checked by a different shop then the one that mounted it (thinking their machine was off) and that shop said it was balanced and true. I only feel this on smooth roads.
I am stuck to think what else could be wrong, help? Bearings are good and I just changed the fork oil.
  • Olive NY
Re: Front wheel hop feeling????
« Reply #1 on: May 27, 2017, 01:58:29 PM »
I'd check everything on the rear as closely as the front.  Bad shock, wheel balance, bearing, whatever back there can manifest itself in the front.  Check your head bearings also.
Offline TommyT
  • New Brick Owner
« Reply #2 on: May 27, 2017, 09:48:28 PM »
Thanks all, I was wondering if something in the rear could be felt like it was up front. The first shop that mount mounted the rear tire couldn't balance it, no adapter, so I rode it for a while without being balanced, had the hop. found another shop that could balance it and that made no difference. I will look into the swing arm bearings and shock and post what I find but it may be a few days before I can get into it.
  • Olive NY
Offline TommyT
  • New Brick Owner
« Reply #3 on: May 27, 2017, 09:49:53 PM »
oh forgot to say that the front bearing seems good, smooth side to side and no play.
  • Olive NY
Offline wally.fisher
« Reply #4 on: May 28, 2017, 02:30:01 AM »
I
Why don't you replace the front bearings? Then you know they're good.
If the problem persists then you may need head bearing adjustment or replacement., be systematic.
Offline TommyT
  • New Brick Owner
« Reply #5 on: May 28, 2017, 07:19:17 AM »
Is there there an easy way to check for play in the swing arm bearings? I did not see anything here on Motorbrick or elsewhere on the internet.
Front bearings replacement, why not? Well that something to consider with 45k miles but so far from what I can tell with wheel off is that there is no poly in them and they move side to side smoothly. It looks like a lot of work to replace them. I plan on doing a major tear down on the bike as I get to the end of the riding season. if more testing does not find something in the rear, I will consider the front bearing replacement.
  • Olive NY
« Reply #6 on: May 28, 2017, 08:57:51 AM »
Parts like motorcycle wheels or swing arms that rotate on bearings are generally designed to have no movement forward to aft or side to side. Trying to wobble them lightly in those directions will show if there is any play. Movement will be subtle so attention must be paid.
Front bearings replacement, why not? . . . what I can tell with wheel off is that there is no poly in them and they move side to side smoothly.
It's morning here so I might need more coffee. What is meant by poly and by side to side? Bearings should be fixed in their positions. Wheels should rotate smoothly but not move from side to side.
Offline TommyT
  • New Brick Owner
« Reply #7 on: May 28, 2017, 09:31:05 AM »
sorry typo, play not poly.
  • Olive NY
« Reply #8 on: May 28, 2017, 09:41:09 AM »
You said you replaced the tires right after you got it -- does that mean you didn't ride it at all before you got the new tires?
« Reply #9 on: May 28, 2017, 09:48:19 AM »
Thanks. How about the side-to-side movement? What's up with that?
« Reply #10 on: May 28, 2017, 09:51:07 AM »
Laitch, I am probably wrong, but my read of that is that he is talking about the steering head bearings and smooth steering movement.
« Reply #11 on: May 28, 2017, 10:01:17 AM »
You don't expect me to think that's sincere, do you? :giggles
So by front bearings wally is referring to steering head bearings and by "they" Tommy is referring to the fork. Blood flow has apparently been restored. Fair poly.
« Reply #12 on: May 28, 2017, 10:02:59 AM »
I've been caught out pretty frequently of late.
« Reply #13 on: May 28, 2017, 10:06:45 AM »
Bad juju, I'm telling you. You should dump that avatar and seek a different personal transformation.
« Reply #14 on: May 28, 2017, 02:10:46 PM »
Sorry guys, front wheel bearings are just that, they fit into the hub of the wheel rim, head bearings are part of the steering swivel action.
You have had the wheel off a few times now, why not replace the bearings with new, you then can check the head bearings if nothing has changed.
« Reply #15 on: May 28, 2017, 03:28:17 PM »
If you'd written wheel it wouldn't have been as much fun translating what you were attempting to convey, wally.  We're all on the same page, although we were anyway. :giggles
Offline TommyT
  • New Brick Owner
« Reply #16 on: May 28, 2017, 07:52:46 PM »
tires - yes, I barely rode the bike before getting new tires. the back tire was 16 years old, the front 13, but both had very little wear, but there was some side rot. I did not think it was safe to ride it with tires like that. Strangle, the bike has 45k miles, 27 years old, by looking at the tires it must have not been ridden much in the last 16 to 13 years.
Front, head bearing, feels smooth side to side.
This hop is light, and I feel it only on smooth roads. The rear shock has 4 positions for damping, I am going to go out an ride soon and try it on all four settings. if it feels like there is NO difference between the settings, I will remove the shock, remove the spring and to see if the shock is dead on damping, but my guess is that it is okay because on the rough roads (and there is a lot of them around here) it would feel very bouncy and so far it does not. Other then this it seems to handle well.
  • Olive NY
« Reply #17 on: May 29, 2017, 01:27:48 AM »
If the bike has been stood so long I suggest you  replace the front fork oil,  old tyres should be replaced. Lotta enjoyable work.
Offline TommyT
  • New Brick Owner
« Reply #18 on: May 29, 2017, 06:52:29 AM »
I did replace the tires, with new Michelin tires front and rear. I did replace the front fork oil right after the new tires, it did help the overall ride but did not change the hop feeling. It does feel a little soft to me with 5 wt oil, I have some 7.5 wt oil now, I think I will try that, plus the old oil looked crappy, I think another fork oil flush would not hurt.
  • Olive NY
« Reply #19 on: May 29, 2017, 06:58:13 AM »
It's more a personal feel ,  some say automatic transmission oil in the forks to be better , some add extra oil, I prefer a 15 wt oil. Trial n error . Are the head bearings good?
Offline TommyT
  • New Brick Owner
« Reply #20 on: May 29, 2017, 09:21:37 AM »
Yes the head bearings seem good, as far as I can tell. With the front wheel off the ground, movement side to side is smooth and at the stop points on each side I do not feel any looseness or play. When hitting rough spots in the road the front end feels good and solid.
I did ride the bike earlier and tried the different shock rebound settings, it did feel better at the stiffer rebound setting then the softest, but no by much. the two middle settings ( there are 4) did not seem to matter much. If I have to guess, I think the rear shock is mostly spring and not much damping if you know what I mean. Its like seeing a car or truck go by with a bad shock, the wheel is bouncing constantly once it hits one small bump. I am going to take it off and remove the spring to see how easy I can move it.
  • Olive NY
« Reply #21 on: May 29, 2017, 10:05:32 AM »
Yup, if that's the original shock it's probably toast.  30-40k was about their limit.
« Reply #22 on: May 29, 2017, 10:14:29 AM »
When mine completely failed, it felt like I was riding a hardtail.
I'm not sure you answered the question whether the hopping was there before you changed the tire. If it was not, then you might have a bulging, i.e. manufacturer's defective, tire. A bulge can be balanced out but is still present. Can you remember whether the hopping was present with the original tire?
« Reply #23 on: May 29, 2017, 12:37:08 PM »
To check the head bearings, bike off the stand, sit on it  n pull the front brake then rock the bike back and forward, if there is play you will feel it.
« Reply #24 on: May 29, 2017, 02:57:54 PM »
When my OEM shock wore out, it bottomed out in potholes and was a hard ride in general. Is this hop occurring at predictable intervals within that speed range or is it random?
