Author Topic: Radio holder removal?  (Read 4385 times)
Offline beemrdon
« on: May 20, 2017, 09:59:17 PM »
Hey there,
I want to get the radio AND IT"S HOLDER out of the left side compartment so as to have more storage. I could get the radio out but the holder would not come out. I did not want to destroy it just in case I ever wanted to put it back. Any suggestions?  :dunno2:
  • The South West... best motorcycling in the US! Longest riding season = 12 months per year
  • 1996 K1100 LT SE, Aspen Silver - Now with 159,xxx miles.
Offline White Dog
Re: Radio holder removal?
« Reply #1 on: May 20, 2017, 10:15:32 PM »
If your K1100 is like my R1100, the left side fairing must be removed and the radio holder is bolted to the gas tank and a cap nut inside the holder.  The electricals as you probably already know can be unplugged, as well as the antenna.  What's going to keep whatever you put in that open hole from falling thru?
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Offline Inge K.
« Reply #2 on: May 20, 2017, 10:20:21 PM »
You have three small holes where you push a small steel wire or jewelers screwdriver through to free
three hooks on the rear side.  (front, rear and outside, if I remember correct).
  • Norway
Offline kioolt
« Reply #3 on: May 20, 2017, 10:46:11 PM »
[size=78%]The radio holder can be removed without removing the fairing pocket that it is in by releasing the 3 spring clips that hold it into the fairing pocket.  I always used a very small screwdriver or a small allen wrench to insert into the three holes.  If you shine a light into the holes you may be able to see the clips that you are trying to release.  [/size]
2018 R1200RT 8,000 miles,2004 R1150RT 189,000 miles
1991 K100LT 128,700 miles,1982 R100RT 106,900 miles
The cheapest thing on a BMW is the nut that connects the seat to the handlebars.
Offline beemrdon
« Reply #4 on: May 21, 2017, 03:59:00 AM »
Thanks folks. I'll check it out tomorrow.
« Reply #5 on: May 21, 2017, 11:19:33 AM »
What Inge was referring to.
Offline beemrdon
« Reply #6 on: May 28, 2017, 02:42:07 PM »
Thanks Scott and everyone else.
Radio gone. What an incredible nest of wires (still left)! I rolled them up, zip tied them and shoved them behind the left speaker, for now anwway. At some point I will follow them up the harness and unplug as many as I can.
If the radio had been half way decent, I would have kept it. The most valuable part, in my opinion, was the cigar lighter....All gone now.
I also took the radio volume control off of the handlebar. Now I have some place to mount a GPS.
As an aside, I had already taken the speaker set up off of the top box.
Lots more storage now.
