Author Topic: R Nine T Front USD Front Fork in K100  (Read 28614 times)
Offline lumpus
Re: R Nine T Front USD Front Fork in K100
« Reply #25 on: August 02, 2017, 11:06:32 AM »
The problem is, that the hole in the rim of the 1150 is only 47mm. There is no Bearing with 47x25mm ...
I have to check the bearing in the 1150.
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
Offline jakgieger
  • itinerant farmer
« Reply #26 on: August 02, 2017, 12:08:37 PM »
Is the reason it looks like there is one rod on top of another because the rod has sections that interlock and slide, lumpus?
He's using one of these... :bmwsmile
  • Kansas USA
  • 1989 K100rs se
Offline bocutter Ed
« Reply #27 on: August 02, 2017, 12:50:13 PM »
Opps went the wrong way. Can you use a 25odx20idx???w collar on the 1150 axle?
  • Toronto, Canada
Offline lumpus
« Reply #28 on: August 02, 2017, 04:18:17 PM »
One Side is 6204. Dimension 47x20x14mm. The other side is bigger.
Gesendet von iPhone mit Tapatalk
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
Offline Mike Flores
« Reply #29 on: August 02, 2017, 07:45:55 PM »
Sounds like you need to have the hub on your new wheel machined to accept the larger bearing size.
  • Los Angeles, CA
  • 1987 K100
Offline lumpus
« Reply #30 on: August 03, 2017, 01:32:57 AM »
Sorry for some misunderstandings that based on my bad english.
The RnineT Forks have a much bigger hole for the axle than the 1150 front wheels bearings inner diameter (and also the outer diameter is 52mm instead of 47). It seems that it is not possible to use the original RnineT axle.
https://www.leebmann24.de/bmw-ersatzteile/view/btdetail/?series=k21&typ=0a06&og=02&hg=36&bt=36_1600
But meanwhile I found a bearing with 47x25x16mm. 63005 2RSR ... this should work.
Or I have to modify the axle?
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
Offline lumpus
« Reply #31 on: August 04, 2017, 01:21:19 AM »
There are two different bearings left/right.
3204 double row agular contact 20x47x20,6mm
6204                                       20x47x14
  • Germany
  • BMW R80, BMW K100
R80 Brat Tracker
K100 RT
