Author Topic: Pop Rivet size for tragkorb latches  (Read 5372 times)
Offline wardie
« on: May 16, 2017, 06:54:55 AM »
I had to purchase a used side cover/lid for my left saddlebag/tragkorb. I've purchased two different length pop rivets and none have worked. SAE size 1/8" diameter.
Cab anyone tell me in inches what size pop rivet I need to rivet the cover latches onto the cover?
This is turning into a PITA. Wardie
Re: Pop Rivet size for tragkorb latches
« Reply #1 on: May 16, 2017, 07:04:16 AM »
How have they not worked? Describe what happened. Don't be so shy about supplying information about the length you used either. Approximately 1/2"/13mm length should do it.
Offline wardie
« Reply #2 on: May 16, 2017, 07:15:17 AM »
won't hold not long enough
Looking at Max fiche looks like 14mm long or about 9/16" length
part number 46 54 2 316 689
« Reply #3 on: May 16, 2017, 07:16:21 AM »
Go get the correct length and follow the instructions of your rivet-installing tool. It will be life-changing.
Offline wardie
« Reply #4 on: May 16, 2017, 07:31:09 AM »
I've pop riveted tons of stuff never found it life changing but the wife and I had three sons that was life changing...thanks
« Reply #5 on: May 16, 2017, 07:39:11 AM »
I went the pop-rivet route which was a very lucky outcome for the kids I never had.
« Reply #6 on: May 16, 2017, 09:18:46 AM »
I used 1/8" on mine, with washers.  Don't remember the length but it was a standard size.  I had the compressed side of the rivet on the inside of the case, but I have the old style latches, newer ones may differ.  Not particularly life changing.
Offline Andy FitzGibbon
« Reply #7 on: May 16, 2017, 11:34:41 AM »
Which latch type?  I just riveted some of the flat-key latches yesterday, using 1/8" x 3/8" rivets and washers under the heads.  The newer latches (with the round locks) may need a different length.
Andy
  • Montrose, WV
