Lawrence, I think you are just used to the airheads. I have wrenched on airheads, oilheads and bricks. All of them are worlds and worlds ahead of any rice burner I have ever owned. But I think my little brick has got to be the easiest of them all. The fewest possible, highest quality, easiest access fasteners get you where you need to be. The hardest squeeze is trying to get that air cleaner to slip out. Other'n that, piece of cake.I look forward to lubing the output shaft this coming winter.
Compare your airhead, where y ou have that air/fuel delivery system designed by Rube Goldberg. Between the two petcocks and the Ts for the crossover, you have 14 hose clamps to keep tight and dry, and you haven't gotten to those air elbows that never seem to fit. Just try and keep your pusoh rods tube gaskets from weeping.
No, I think it's just you're used to the airhead. I'm betting the first time you tried to pop off an airhead valve cover you cussed the guy who hid those little nuts back behind the fin where you can't see them and don't expect them. Once you get used to the way the brick is laid out, you'll admire how it's put together.
No matter. The airheads are all long in the tooth, now. And the newest beemers are strictly for guys who have more dollars than sense.
