Any advice for replacing fork seals
Topic: Any advice for replacing fork seals (Read 3169 times)
Supershooter
^ Proficient Motobricker
May 07, 2017, 10:54:45 PM »
I removed a fork to replace the seal and am wondering if there is a tip or trick to get it reinstalled correctly? Im concerned about having my forks correctly aligned when I'm done.
Supershooter
Liberty Township, O'brien County, Iowa
85 K100 RT
Martin
Re: Any advice for replacing fork seals
Reply #1 on:
May 07, 2017, 11:15:54 PM »
Keep the distance the tubes protrude through the triple tree the same and try sliding the axle in. If the axle slides in smoothly with out binding you have it aligned. If the axle requires hitting with any form of hammer up to and including a sledge it is out of alignment. It should push in with the palm of your hand a little lubricant is allowable.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
Supershooter
Reply #2 on:
May 08, 2017, 10:25:41 PM »
After watching Chris Harris tear apart a set of forks off a R65, I've decided to reinstall the fork that I removed and replace the seals with the forks on the bike. I'll grab a few crush washers and set started later this week.
Supershooter
85 K100 RT
