Author Topic: Coolant leak in  (Read 5927 times)
Offline nrussell
  • nrussell
Coolant leak in
« on: May 05, 2017, 08:21:44 PM »
Hello!
Very nice forum. I have read and learned a lot.
Thank you very much in advance.
Today  after 15 minutes way to work, I discovered a coolant leak/drip in my 94' K1100RS. It stops when engine get cold.
Later in home (cold engine), I open the radiator cap and the leak start driping (). Puting the cap again and the driping stops.
What would you do?
What is the name/part number of the leaking piece?
I'm posting a video and 2 pictures for your reference.
Best regards,
Nicolás
Offline nrussell
  • nrussell
Re: Coolant leak
« Reply #1 on: May 05, 2017, 08:40:01 PM »
Sorry for the mess with the video.
Here are the pictures
Offline jakgieger
  • itinerant farmer
Re: Coolant leak in
« Reply #2 on: May 05, 2017, 08:47:02 PM »
Your head is different than my 2v head, but that sure looks like a soft or .  A very easy repair if you can get a straight shot to put the new one in.  Good luck!
  • Kansas USA
  • 1989 K100rs se
Re: Coolant leak in
« Reply #3 on: May 05, 2017, 09:14:10 PM »
If one is leaking, any others should be replaced, too, even if they are not leaking yet. When the old one is removed, clean out the debris from the block; smooth off the edge of the hole with emery cloth then install the replacement. Flush the coolant system when you are finished then add fresh coolant in the correct proportion with distilled water for your climate.
Offline nrussell
  • nrussell
Re: Coolant leak in
« Reply #4 on: May 06, 2017, 08:37:53 AM »
Thank you very much Jack and Laitch.
I have removed the plug and it has a little hole in there. I'm know going to buy a new one.
BR
Enviado desde mi SM-J710F mediante Tapatalk
Offline jakgieger
  • itinerant farmer
Re: Coolant leak in
« Reply #5 on: May 06, 2017, 08:45:11 AM »
To show your appreciation, how about posting a picture of that red k1100 rs in your avatar!!  :bmwsmile
  • Kansas USA
  • 1989 K100rs se
Re: Coolant leak in
« Reply #6 on: May 06, 2017, 09:04:26 AM »
. . . how about posting a picture of that red k1100 rs in your avatar!!  :bmwsmile
That's a cheerful avatar!
Is that oxidation around the rim of the engine block freeze plug opening?
Offline nrussell
  • nrussell
Re: Coolant leak in
« Reply #7 on: May 06, 2017, 09:05:18 AM »
Of course!
I think it was already on the avatar. I'm going to double-check. But here it is my red k11rs.
Re: Coolant leak in
« Reply #8 on: May 06, 2017, 09:19:01 AM »
Of course!
Breathtaking!  :yes
Offline jakgieger
  • itinerant farmer
Re: Coolant leak in
« Reply #9 on: May 06, 2017, 12:29:35 PM »
Very nice!
  • Kansas USA
  • 1989 K100rs se
Offline nrussell
  • nrussell
Re: Coolant leak in
« Reply #10 on: May 06, 2017, 08:48:12 PM »
Job finished.
22mm freeze plug.
Thanks!
