Author Topic: New forum member from southern Wisconsin  (Read 21403 times)
Offline Hilltopper46
« on: April 29, 2017, 01:16:27 PM »
Hi;
I'm a new forum member - I just purchased a 1995 K1100LT with 80K+ miles on the odometer. It has some issues.
I'm hoping to attach at least a couple pictures to this post - getting them from the phone to the post might be a challenge.  My regular laptop is broken at the moment and I am working from a desktop machine that is 10 years old.
So the obvious things are:
- the battery is flat
- the pedal for the rear brake goes all the way down, there is no fluid in the reservoir
- there is a funky leak of some sticky stuff on the left side of the bike on  the muffler - is this the brake fluid?
- the front tire is bald
One thing I like already - this thing is a lot easier to "undress" than the GoldWings I used to ride!
I think the PO "stored" it outside for a couple years.  I'm not sure what the history is - he had 3 Harleys in his garage plus this beast.  I made him an offer based on his supplying a clear title for it. He had moved from another state and lost the title in the process. He was able to do this so I picked the bike up  yesterday.
One other question - the PO says the bike goes through rear brake pads pretty quickly, about 1 a year.  Is that normal, or is there something I can look for to remedy the situation.  It looks like it could stand to have the rear rotor replaced.
And another question - the saddlebags have sort of a haze on the top of them - what's the best product to clean that up?
I'm sure there will be a lot more questions as I get more familiar with the bike.
  • East Troy, WI
  • 1995 K1100LT
Current bike - 1995 K1100LT - It RUNS!. You says Plum, DMV says Purple, BMW says Navana Violet.
Previously: 1982 XJ650 Yamaha, 1987 GoldWing, 1995 GoldWing, 2001 FLSTC, 2003 Goldwing
Re: New forum member from southern Wisconsin
« Reply #1 on: April 29, 2017, 04:28:36 PM »
What Johnny said!
If it was mine I would head out to the Hardley Fergusen dealer and get me some S-100 motorcycle cleaner.  That stuff is like detailer in a bottle.  Before I did anything I'd pull the tank, seat and the battery and clean everything up with the S-100. A sponge and a  couple of old paint brushes are great to loosen dirt in all those nooks and crannies.   When you're done, all the other jobs will be like working on a new bike.
You also want to get a can of DeOxit electrical cleaner and start a program of shooting a bit of it into every electrical connection you can get to.  These old motobricks have a lot of electricity running around in them, and you don't want it not getting to where it needs to be.
Sounds like you might have a bad rear master cylinder.  If it is, the good news is that some of the inmates here have found a $6 replacement from China that takes an afternoon to retrofit and works at least as good as, if not better than, the original.
The rear pad thing sounds like a sticky caliper that will probably require a tear down and clean up.
If Johnny's Pledge on the tragkorbs doesn't work, an option is to hit them with a coat of flat black followed by DupliColor Matte Clearcoat for wheels, followed by a very light wet sand with 1200 grit.  I have done several sets with it, and it's as close to the original finish as you can get.  Makes them easier to clean as well.
From the pictures, it looks like you might have gotten a pretty nice deal on a real mile muncher.
« Reply #2 on: April 29, 2017, 04:39:00 PM »
Welcome to the asylum from the land of OZ. Link for replacement M/Cyl   http://www.motobrick.com/index.php/topic,9364.0.html . Surf City make a product called Black Max it's good on plastic restoration. On old Bricks Deoxit will be your best friend.
« Reply #3 on: April 29, 2017, 05:30:10 PM »
Welcome, Hilltopper46!
Your new possession is dressed out in the highly desirable plum motif, sought by fruitarians worldwide.  :clap:
« Reply #4 on: April 29, 2017, 10:48:02 PM »
That's nice to know - I've already taken a hard time from one of my friends (Harly rider) over the color. I previously rode an illusion blue GoldWing, sold in 2011.
  • East Troy, WI
  • 1995 K1100LT
Offline Rcgreaves
« Reply #5 on: April 29, 2017, 11:02:02 PM »
Hey hilltopper,
With that handle I thought perhaps you were in my neighborhood, Platteville high motto I believe is hillsman or hilltoppers,  I forget.
Im over west of Dodgeville.  Welcome.
Doing “better than I deserve"
« Reply #6 on: April 29, 2017, 11:19:10 PM »
Hey hilltopper,
Oddly enough, that part of the country influenced this handle - I've used it for years on different forums.  The hills in western Wisconsin are some of my favorite riding areas, so when selecting a handle, I tried Hilltopper, which was taken, so after trying Hilltopper1, and 2, etc, I settled on my age which was 46.  I'll be 64 this summer, so I guess it's been my handle for 18 years....
I live at East Troy.
  • East Troy, WI
  • 1995 K1100LT
Offline bocutter Ed
« Reply #7 on: April 30, 2017, 12:03:01 PM »
With that handle ...
I see natural-edged black walnut, turned green ...  :yes
  • Toronto, Canada
« Reply #8 on: April 30, 2017, 03:20:02 PM »
I see natural-edged black walnut, turned green.  :yes
:clap: :clap:
Cut down in September 2015.  You can see all my stuff at Opa's Pens.
(if this is against forum rules - admin may delete with no hard feelings)
  • East Troy, WI
  • 1995 K1100LT
Offline bocutter Ed
« Reply #9 on: April 30, 2017, 05:24:31 PM »
:clap: :clap:
Ya, done a few of those ...
This one is black cherry crotch, yard tree, about 22" diameter ...
  • Toronto, Canada
Offline bocutter Ed
« Reply #10 on: April 30, 2017, 05:56:39 PM »
  • Toronto, Canada
« Reply #11 on: April 30, 2017, 11:12:10 PM »
 :clap: :clap: :2thumbup: :2thumbup:
  • East Troy, WI
  • 1995 K1100LT
Offline jakgieger
  • itinerant farmer
« Reply #12 on: April 30, 2017, 11:54:52 PM »
Welcome to the Knut haus :bmwsmile (also known as the asylum)!  What implement manufacturer did you work for?  Several of my machines came from your area...
  • Kansas USA
  • 1989 K100rs se
« Reply #13 on: May 01, 2017, 12:00:47 AM »
I worked for J. I Case from 1973, through the iterations of Case IH and Case New Holland until 2015. Started as a mechanic in a company store in Indianola IA.
  • East Troy, WI
  • 1995 K1100LT
Offline jakgieger
  • itinerant farmer
« Reply #14 on: May 01, 2017, 08:04:20 AM »
:2thumbup: You will get along fine with the bike.  Everything is straightforward/intuitive.  If you cannot solve your questions, and search yields no adequate answers (Laitch just posted on a fairly reliable method), the forum will help...you just gotta be specific, detail your actions up to the point of question, and include relevant pictures!  That K1100 is about as bulletproof as a machine can be :bmwsmile .  On the equipment, we have a Meyers spreader and some Badger forage equipment.  Good luck
  • Kansas USA
  • 1989 K100rs se
« Reply #15 on: May 01, 2017, 01:08:17 PM »
So... the funky looking leak (see the picture above) is shock absorber oil from a remote reservoir that is sitting above the ABS unit.  Thinking this isn't stock....
  • East Troy, WI
  • 1995 K1100LT
Offline jakgieger
  • itinerant farmer
« Reply #16 on: May 01, 2017, 03:26:06 PM »
Not stock...lots of options there depending on brand (rebuildable, etc.)
  • Kansas USA
  • 1989 K100rs se
« Reply #17 on: May 02, 2017, 05:35:41 PM »
And the saga continues....
The rear brake bled out and has stayed up with no leakage over night.  :2thumbup: I put an Odyssey battery in it and after several seconds of cranking, it fired up.  :2thumbup:
I buttoned it up, got it down off the center stand and rode it to the end of the street and back, about 3/4 mile.  :yow Now the starter won't engage.  You can hear it spinning, but the engine isn't turning over.
Where do I hit it with the hammer and how hard?  :hehehe
  • East Troy, WI
  • 1995 K1100LT
« Reply #18 on: May 02, 2017, 05:54:56 PM »
sprag clutch is stuck.  Happens with old K's, unfortunately.  Several threads here on how to deal with it.  It's a bear to get to but probably just needs some oil.
« Reply #19 on: May 02, 2017, 06:07:50 PM »
sometimes changing to Mobil One or adding a can or Rinsoline or some such gum-solvent can cure the problem, best bet is preventive maintenance, regular oil changes.  Sounds drastic but if it happened to me I'd drill a hole in the housing where the sprag clutch is located and lube it directly.
« Reply #20 on: May 02, 2017, 06:11:41 PM »
  You can hear it spinning, but the engine isn't turning over. Where do I hit it with the hammer and how hard?  :hehehe
Looks like you've successfully made the transition from New Member Introduction to Victim's Statement, Hilltopper46. :giggles Future challenges should be posted in the Workshop Section.
As far as this one goes, Chaos is on it except for the hole drilling. I think that is premature in your case.
Here is a description of the sprag assembly. Scroll down to What are the SYMPTOMS and simplest fix . . .  and If things are more than just beginning . . . to find solutions.
So do what is recommended at the link. Before you reach the hole drilling stage—which I think should be last resort—the sprag clutch also can be lubed by removing the crankcase cover to get access for lubrication.
There is a video in this post to use for comparison with your situation.
« Reply #21 on: May 02, 2017, 08:36:40 PM »
...successfully made the transition... best line I've heard for a while.  I'll make sure to move to the proper forum for future challenges.
Quote
I'd found the bit about drilling the hole through searching. What ever I decide to do, it will give me something to do until the front tire arrives.
It sure felt good to get back on a bike, even though it didn't last very long.
  • East Troy, WI
  • 1995 K1100LT
« Reply #22 on: May 02, 2017, 08:50:04 PM »
Welcome Hilltopper!
You've come to the right place for K-Bike questions and issues.
I grew up in Monroe WI and have made a couple of trips back with my Brick to include the MOA Rally in St. Paul and hope to make it back again this year.  It's fun to follow the "alphabet" roads through the state.
My '93 K75S has been my commuter mule and my touring bike for a number of years the smoothness and comfort are unbeatable.  As others have said, it is repairable by the home mechanic and a good machine.
« Reply #23 on: May 02, 2017, 10:46:39 PM »
Of course it is!  But I have power tools aching to pounce on my K  :eek:
Offline jakgieger
  • itinerant farmer
« Reply #24 on: May 02, 2017, 10:56:40 PM »
Drill baby, Drill  :hehehe
  • Kansas USA
  • 1989 K100rs se
