Author Topic: Handlebar replacement options  (Read 8071 times)
Offline Brick_hack
« on: April 28, 2017, 02:03:23 PM »
Hi all, I tried the search feature with no avail. I would like a handlebar with less sweep for my '97 K1100LT. The current one cocks my wrists at a weird angle that they don't like very much. Does anyone have any suggestions on bars that they have tried, or are aware of?
  • Bellefontaine, OH
  • 1997 K1100LT
Offline mw074
Re: Handlebar replacement options
« Reply #1 on: April 28, 2017, 02:36:10 PM »
I am a big fan of "C" bars with risers on the 1100LT.
  • Michigan
Offline Brick_hack
« Reply #2 on: April 28, 2017, 02:48:29 PM »
greetings..
did you see this...
I had not seen that, thank you very much!
  • Bellefontaine, OH
  • 1997 K1100LT
Offline richarddacat
« Reply #3 on: April 30, 2017, 08:47:35 PM »
I'm running the "C" bars with risers and sure would like to find something wider, I find myself with my palms on the bars-ends.
From what I've read the K1 bars are wider but finding them is like hens teeth.
Offline Brick_hack
« Reply #4 on: May 01, 2017, 11:35:38 AM »
Thanks, I'm half tempted to just try some aftermarket bars since I'm not having any luck finding a set of "C" bars.
  • Bellefontaine, OH
  • 1997 K1100LT
« Reply #5 on: May 01, 2017, 01:50:32 PM »
Got get a Flanders 22mm low sidecar bar. 27" wide. You might need different risers because it will lower you a couple of inches.
« Reply #6 on: May 01, 2017, 01:51:16 PM »
http://www.kbikeparts.com/#Handlebars/Controls
Offline Brick_hack
« Reply #7 on: May 01, 2017, 02:31:10 PM »
Wow, thanks for that resource! Really appreciate it. Would any 7/8" handlebar riser work? I like the look of the Renthal road high bar.
  • Bellefontaine, OH
  • 1997 K1100LT
« Reply #8 on: May 01, 2017, 03:01:23 PM »
Any? I don't know. 22mm is a smaller diameter than 7/8".
Offline Brick_hack
« Reply #9 on: May 01, 2017, 03:09:46 PM »
Hmm. But if I got 7/8" risers and sanded them to fit the BMW, then I could run my renthal bar... and sand it gently so the controls fit properly....
  • Bellefontaine, OH
  • 1997 K1100LT
« Reply #10 on: May 01, 2017, 03:11:30 PM »
Knock yourself out.  :riding:
Offline Brick_hack
« Reply #11 on: May 01, 2017, 03:18:27 PM »
Don't tempt me  :eek:
  • Bellefontaine, OH
  • 1997 K1100LT
