Author Topic: Inlet Manifold Rubber (TOP) alternative clips suggestions  (Read 9306 times)
Offline Vespa no more
« on: April 13, 2017, 06:43:16 PM »
I need to replace the one-use clips on the rubbers between the plenum and the throttle bodies
Does anyone know a source of alternative screw clips?
Went to the local monolithic hardware store and their jubilee / radiator style clips were too wide to fit into the recess in the rubbers.
Thanks
Guy
  • Wollongong NSW AUSTRALIA
Offline wmax351
Re: Inlet Manifold Rubber (TOP) alternative clips suggestions
« Reply #1 on: April 13, 2017, 07:00:20 PM »
Take a look at McMaster Carr. They might have something that would work.
  • Albuquerque, NM
Bikes:
« Reply #2 on: April 13, 2017, 07:03:06 PM »
Oetiker crimp clamps on EBay but they require a special tool which is also available on Ebay. There is another type I will post when I find it. Try searching stainless steel hose crimp clamps.
Offline Filmcamera
« Reply #3 on: April 13, 2017, 07:52:43 PM »
To be honest I am running zip ties on mine - seems to work...
  • San Jose, Costa Rica
Poserbricker
Offline jakgieger
  • itinerant farmer
« Reply #4 on: April 13, 2017, 08:02:57 PM »
Rigging like THAT will get you banned from the forum :hehehe :hehehe
  • Kansas USA
  • 1989 K100rs se
Offline Filmcamera
« Reply #5 on: April 13, 2017, 08:04:46 PM »
Lol well I do have four of the one time use thingies but I am saving them for when I am semi convinced they will be one time used for more than two weeks...
Poserbricker
Offline Elipten
« Reply #6 on: April 13, 2017, 08:22:02 PM »
I have used these below and others from McMaster Carr that Frankenduck sold me.
Clamps for throttle bodies 50mm uppers, 48mm lowers
3 x 09402-48208 CLAMP Suzuki
3 x 09402-50205 CLAMP Suzuki
Bought from Partzilla.com
  • San Antonio, TX
  • 1990 K75RT
« Reply #7 on: April 13, 2017, 08:32:57 PM »
My god!
That's a catalogue.
Going through the index, I got distracted by flags. Disappointing that I couldn't get a Syrian flag but good to see the Australian one at the top of the list. When living in Colorado, it used to amuse me to see the weekend warriors on their harleys with a stars and stripes bandanna on their heads NO helmet. Just the ticket for full cranial protection.
Thanks for the replies - am confident that I will find what I need.
And if it comes to that, I do have a good selection of cable ties
Guy
« Reply #8 on: April 13, 2017, 09:36:14 PM »
http://www.partzilla.com/parts/detail/suzuki/SP-09402-48207.html
They have been recommended on another K bike forum.  I have a set for my K75.
« Reply #9 on: April 14, 2017, 01:50:00 AM »
Found it cheaper source of Oetiker clamps and the tool. I don't know if they are big enough but the tool is cheap. You might need to contact them to get the correct size.  :dunno  I also suggested stainless zip ties used in conjunction with the zip tie gun, would be better than standard nylon ties. https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214607&SearchText=oetiker+hose++clamps
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214758&SearchText=+hose+crimp++clamps
Offline wmax351
« Reply #10 on: April 14, 2017, 09:19:36 AM »
The crimp clamps can be crimped with wire-cutters (if you have side access, like on a CV boot) or with nippers/flushcutters if you don't. http://www.harborfreight.com/4-inch-end-nipper-pliers-39531.html
  • Albuquerque, NM
Bikes:
« Reply #11 on: April 14, 2017, 09:23:19 AM »
I admire a man who takes up the challenge of outwitting destiny!
Offline Filmcamera
« Reply #12 on: April 14, 2017, 09:27:50 AM »
In a couple of months when we are deep in the rainy season I plan on opening up the engine to check the valves and also overhauling the throttle bodies etc - that is when I am going to use my precious one time use clamps!  Until then I will continue with my zip ties which may not be good but are better than what was on the bike when I got - nothing at all.
Poserbricker
« Reply #13 on: April 14, 2017, 09:32:27 AM »
They work. Who could ask for anything more than that?
« Reply #14 on: April 15, 2017, 12:36:09 AM »
Having several nail removing pliers, might sacrifice the sharp edge on a pair and use them.
Still prefer to use screw or bolt hose clamps.
Am searching and will post the solution (if I find it)
It's out there
GF
« Reply #15 on: April 15, 2017, 09:12:12 AM »
Here's a photo of the Suzuki clamp I mentioned above.  Not sure what you're looking for, but they worked on other bikes.
« Reply #16 on: April 15, 2017, 09:13:42 PM »
Exactly what I had in mind.
Will do the rounds of both the hydraulics shops and the various bike shops...
I used to have a suzuki SV650 and was pleased with the service and knowledge at the spares counter (more than I can say for the BMW outlet I try my [/size]best to avoid).
[/size]
[/size]Public holiday tomorrow then I'll be into it.
[/size]
[/size]Thanks again
[/size]
[/size]Guy
Offline JR67
« Reply #17 on: April 23, 2017, 06:55:19 PM »
I just went to the motorcycle wrecker around the corner; went through his bin of skinny hose clamps and walked out with 12 clamps of the right size for $10. Nothing wrong with recycling in my book.
  • Victoria, BC, Canada
  • 1993 K1100LT, 1982 Guzzi LeMansIII, 1995/1971 Guzzi Quota project, 2005 Honda Big Ruckus
