I have three spare final drives lying around and they all leak some gear oil into the spline cavity. It doesn't leak out between the mating surfaces of the FD and swingarm, but every 6000 miles when I pull the FD to replace tire/lube splines a bit of gear oil is visible in there, maybe a teaspoon or so. So I'd say I'm in need of a seal replacement but not sure which one. I've read this:
http://www.motobrick.com/index.php/topic,7029.0.htmlAnd what I can say for sure about that procedure is, maybe I can do it but odds are good that I won't. The cost-benefit of that action justifies taking it somewhere and paying the whatever...
Despite the little bit of fluid, the splines are adequately lubed and it doesn't appear that that bit of gear oil is washing the lube (Guard Dog) off the splines. So the question is, am I the only one with seepage past whichever seal that is and what's the I-can-live-with-that tolerance there? And what is the likelihood of that seepage resulting in failure that will kill me or my driveshaft or both?
Comments appreciated...
MH
