Author Topic: 1985 K100RS Tripple Black  (Read 10156 times)
Offline ESveen
« on: April 08, 2017, 02:37:23 PM »
The short version:
  • Trondheim, Norway
  • 1991 K1 & 1992 K100RS
Offline Boxermann
Re: 1985 K100RS Tripple Black
« Reply #1 on: April 08, 2017, 03:12:45 PM »
Ser meget bra ut!
(Looks great..)
  • K100 / '87, K75 / '87
Offline F14CRAZY
« Reply #2 on: April 08, 2017, 09:41:50 PM »
That RS in the 1st pic looks great
  • Grand Rapids, MI
  • '87 K75C
Offline MaraudeRS
« Reply #3 on: April 08, 2017, 09:48:38 PM »
3 pics? That's all we get?! C'mon man, don't tease! It looks great but I want to know and see more
  • Monterey, CA
  • 1992 K100RS
Offline ESveen
« Reply #4 on: April 09, 2017, 01:22:22 AM »
Hi again.
The red RS was nice, but it was stolen and left on the side. All of the plastic was damaged, and the motor had a crack under the timing cover. It had run 178.000km and the main seal was leaking and the clutch was bad.
I got my hand on another motor and started with this. Changed all seals, gasgets and o-rings on the motor. The seal on the gearbox was fine.
I hope i get the picures out in the right order, it has been a while since all of this :)
  • Trondheim, Norway
Offline ESveen
« Reply #5 on: April 09, 2017, 01:37:43 AM »
Changing simmering and clutch. Got a centering tool from motorworks. Bought a refurbished water/oil pump also from motorworks, mounted with liquid seal and new bolts.
Mounted starter and alternator with new rubber and new regulator.
  • Trondheim, Norway
Offline ESveen
« Reply #6 on: April 09, 2017, 01:47:49 AM »
Motor and gear back together with starter and alternator. Used 4 m6 studs to guide the gearboks back on the motor. Everything is mounted with torque specs from the manual.
  • Trondheim, Norway
Offline ESveen
« Reply #7 on: April 09, 2017, 06:11:01 AM »
Chopped the frame and removed all unnecessary parts. Welded some plugs in the back of the frame. Sandblasted and powdercoated black.
Moved the ignition switch down to the airbox.
  • Trondheim, Norway
Offline ESveen
« Reply #8 on: April 09, 2017, 06:24:02 AM »
New bearings and new bolts/nuts/retainers in the front end. Sandblasted and powdercoated upper/lower clamps.
New rubber airmanifolids and rubberbend from filterbox. Also the breeding hose from the motor is new.
Sorry if i sometimes mix some terms or name of parts. My Norwegian is better!
  • Trondheim, Norway
Offline ESveen
« Reply #9 on: April 09, 2017, 02:16:59 PM »
Handlebar from lokal partsdealer. Wanted a handlebar and not strap-ons because of comfort. New rubber mountings.
Everything on the handlebar is brand new. From rubbergrips to switches.
New exhaust coppergaskets.
Mounted headlight, blinkers and horns low/high frequenze.
Rims came back from powdercoating.
  • Trondheim, Norway
