Author Topic: Threebond 1216  (Read 9272 times)
Duc750
Threebond 1216
« on: September 05, 2011, 09:17:03 AM »
What is a good substitute for threebond 1216? - it doesn't seem to be available in the UK
Re: Threebond 1216
« Reply #1 on: September 05, 2011, 02:05:18 PM »
Depends what you are using it for.
For a lot of the Metal/Metal contacts on BMW's I use Permatex anaerobic gasket maker. Works pretty well, and dissolves and stays soft when it squeezes out.
Phil Marvin
Re: Threebond 1216
« Reply #2 on: September 06, 2011, 12:38:50 PM »
Hi, Duc750,
    Dreibond, if still available in the USA from BMW dealers, is quite expensive.  In lieu of Dreibond, I have used Hondabond, Yamabond and Permatex Ultra-gray.  All have worked as intended.  I have used them for the seal between cylinders and block on airhead BMW's and the spots necessary between valve cover and head on various K75's and K1100LT's.  I hope this helps.
