Author Topic: Major triple tree problem . Update !!  (Read 4813 times)
Offline whosyurdaddy
« on: March 24, 2017, 08:03:38 PM »
  I have a 91 k100rs with a cracked upper fork cross brace . Can anyone tell me what other brace might work with this bike . Beemer Boneyard shows no stock (I will call) but I did find a brace that looks identical to mine from a 93 k1100rs but different part number . HELP
  FYI I installed the upper fork brace from the 93 K1100RS and its a direct fit even though it has a different part number . The only difference is the bushing area for the handle bar mounts has been redesigned  and requires a bushing change .
  • Central Indiana
  • 1991 K100RS SOLD
Re: Major triple tree problem
« Reply #1 on: March 24, 2017, 08:47:34 PM »
search K100 triple tree on ebay, all sorts of stuff pops up cheap.
Offline Snowman
  • Aberdeen SD.
« Reply #2 on: March 25, 2017, 12:19:27 PM »
$25-$50 on Ebay all day long. Good luck.
« Reply #3 on: March 25, 2017, 12:59:50 PM »
    According to part numbers and info I could find the 91-92 k100rs is a different animal . I did find one from a 93 k1100rs that appears to identical but different part number . The parts that mount to this (93) bracket have the same part numbers as the 91 bracket . I'm going to take a chance on the 93 bracket if it doesn't work , more wall art . I wished I had enough knowledge to know the minor differences  between some of the bike parts.
  • Central Indiana
  • 1991 K100RS SOLD
« Reply #4 on: March 25, 2017, 03:49:02 PM »
When you get it you will be able to add to the combined knowledge of this site. It is by you taking the first step that the knowledge progresses.
« Reply #5 on: March 25, 2017, 04:50:35 PM »
I'm not sure what years but didn't they change to Showa forks at some point, also changed  the brake line from running through the triple clamp stem.  Could account for the differences.
« Reply #6 on: March 26, 2017, 06:48:00 AM »
I'm going to take a chance on the 93 bracket.
Then you would also need the rubber mounts for the handlebar clamps as these have a different shape,
and so does also the seats for the rubber mounts in the triple tree.
