Author Topic: Troublesome battery anchor  (Read 5200 times)
Offline Rcgreaves
« on: March 19, 2017, 09:30:31 PM »
So my new to me K75s 1987 came with a Westco battery that when you place the bar over the battery and run the long bolts 176mm btw , the theads don't even engage with the base without twisting the bar bending/distorting it to grab a thread or two.
The battery appears to be slightly taller than the OEM unit.  Anybody else experience this?  Whats the fix?
Ever try to buy a 180mm x 6mm x 1.0mm bolt?
I tried adding a coupler at the base  with threaded rod in the base...only the 10mm of thread I ran above the plate into the coupler makes the top of the bolt hit the ecm brick above the battery.  tight clearance....
This just feels stupid, but if I could BELT SAND 1/8" of plastic off the base of the battery :mbird  the original bolts would work...How much meat is there on the bottom of that casting.  stupi\de.
Or,  I thought about somehow building a recess into the bar that would bottom out the bar a few MM lower.  Id have to weld a thimble shaped socket to the bar, below the hole.   complicated fab....
I could divot the bar with a punch, cold stress or may heat with a torch and beat on the hole area to drive the top of the bolt lower by a few MM..
ideas?  help!
Doing “better than I deserve"
Offline Rcgreaves
Re: Troublesome battery anchor
« Reply #1 on: March 19, 2017, 10:09:46 PM »
so dimple the bar to have a lower location for the hole..I can certainly heat it red, blacksmith style divot the metal and repaint...only need a few mm. Jonny.  thanks.
Offline kioolt
« Reply #2 on: March 19, 2017, 10:42:21 PM »
If you want to go the route of buying a longer bolt you can get them at mcmaster.com for a littler under $7 each.
« Reply #3 on: March 19, 2017, 11:08:41 PM »
When the bar is on the battery are the flanges of it resting on the battery or is the longitudinal center of it?
Offline Andy FitzGibbon
« Reply #4 on: March 20, 2017, 06:33:27 AM »
I have the same problem with my "Big Crank" ETX-30L battery from batterymart.com.  Haven't done anything about it yet, but plan to get either longer bolts, or nuts and all-thread. Going to need a fatter rubber grommet to retain the coolant reservoir as well.
Andy
  • Montrose, WV
Offline RobP
« Reply #5 on: March 20, 2017, 07:57:39 AM »
When I bought my Wesco battery from Beemer Boneyard they included the longer bolts - or I ordered them from there, I forget.  I made a longer grommet to hold the coolant reservoir using a cut-off section of a rubber leaf spring bushing that I found in my 'leftovers' supply bins.
RE: Ever try to buy a 180mm x 6mm x 1.0mm bolt?
Bolt Depot has 'em  http://www.boltdepot.com  , so does McMaster-Carr https://www.mcmaster.com
  • Driftwood, TX
  • 1985 K100RS
Offline Rcgreaves
« Reply #6 on: March 20, 2017, 09:14:42 PM »
Greetings Brick bretheren.
Laitch, best I can tell, I have the bar oriented with the battery touching the longitudinal in the upright orientation.   :clap:
So today I patronized my local specialty hardware vendor Fastenal and while they didn't have the length I require they did have lengths of threaded rod, so reluctantly and knowing the weather is balmy I opted for the scheppo fix...threaded rod and doubled nuts.
Then to my rescue was Brick newb Robp and his online vendors suggestions.  I had prowled mcmaster a month back and they didn't have it in stock however this boltdepot.com looks to be the solution I required  thanks for the tip.  The rod will get returned...:
2 pieces#15453 - Metric socket cap, Class 12.9 steel black oxide finish, 6mm x 1.0mm x 200mm
$4.66
$9.32
Shipping$4.95Total$14.2
