Author Topic: Well crap! Rear shock seals  (Read 8790 times)
Offline milq
« on: February 24, 2017, 12:32:16 PM »
Just came out to install a new front tire and noticed oil under the final drive...shock seals are toast on the Works Performance unit.
Spoke with them and looking at up to $300 to rebuild since there's no idea how big the original purchaser was, etc.  $500+ to replace.
Anyone have any thoughts? Should I be looking at RAM or others instead?
  • Southern IL
  • 1988 K75S
Re: Well crap! Rear shock seals
« Reply #1 on: February 24, 2017, 12:37:53 PM »
Just replacing the seals at WP is pretty cheap. Forgot how much it was for me, but definitely not 300, and mine was seals, bladder, and shaft.
« Reply #2 on: February 24, 2017, 12:43:44 PM »
My Works blew out after a couple years, replaced it with a Progressive. Someone just posted about getting Ram Shocks for about $325, http://www.ramshox.com/
« Reply #3 on: February 24, 2017, 01:14:10 PM »
I don't know what they were quoting you, but I had the Works shock on my K75S rebuilt after a seal blow out and a longer shaft installed about a year and a half ago.
Shaft, seals, bladder and labor was less than $200 if I recall correctly.  I think seals and bladder are about $70 or so.  Could go back and find the invoice.
Go to their web site and check the price list.  They are pretty reasonable.
Offline milq
« Reply #4 on: February 24, 2017, 01:18:39 PM »
Yeah, he said $100 for just an inspection and service, but I'm pretty sure I'm significantly heavier than the owner that bought the shock. The guy I bought the bike from is 60lbs lighter than me and he liked it a lot. It squats pretty bad with me on it (270lbs) so I suspect a spring and re-valve at a minimum. Also unknown mileage on the shock, so bushings could be worn, etc.
  • Southern IL
  • 1988 K75S
« Reply #5 on: February 24, 2017, 02:27:46 PM »
Which model is it? With the multi-rate setting, you could put it to the 2nd setting (normally for passenger and no baggage) and that would help a bit.
All in all, I'd say it's worth paying for them to fix and/or update it. It's cheaper than a lower quality shock would be new.
Offline milq
« Reply #6 on: February 24, 2017, 05:02:43 PM »
Looking at their site, it appears to be a Tracker with dual rate springs and remote reservoir. No apparent adjustments for rebound or compression that I can see.
  • Southern IL
  • 1988 K75S
Offline milq
« Reply #7 on: February 24, 2017, 05:04:41 PM »
  • Southern IL
  • 1988 K75S
« Reply #8 on: February 24, 2017, 05:28:48 PM »
Tracker with three rate springs.  Looks like the adjustable preload is in the lowest position.
« Reply #9 on: February 24, 2017, 05:52:09 PM »
I think you've got one of these and it has a couple of adjustments. Read all about it, even if that isn't it. :giggles
« Reply #11 on: February 24, 2017, 08:11:20 PM »
Offline milq
« Reply #12 on: February 24, 2017, 09:17:31 PM »
You guys are the bestest. If I can get Works to sell me a seal kit and find someone that can charge it with nitrogen, I'd be in business!
  • Southern IL
  • 1988 K75S
« Reply #13 on: February 24, 2017, 09:43:11 PM »
I did that, and I'd recommend you just send it in: doesn't cost much more to have them do it. I think putting it back together was how my shaft got bent.
[/size]
Taking the springs off is a PITA. I had to weld a jig together to do it the second time. I got them powdercoated, then sent the powder coated springs and the shock off to works, they had it back in a week or two IIRC.
« Reply #14 on: February 24, 2017, 09:45:49 PM »
Most any Japanese bike dealer will have access to the equipment to charge your shock.  My local Kawasaki dealer charges mine every two years for $12.  It's about as complicated as filling a tire.
Their setup is pretty simple once you have a nitrogen tank and a regulator with a good gauge.  Basically it is a screw on chuck with a manual depressor for the Schraeder valve.
Offline Snowman
  • Aberdeen SD.
« Reply #15 on: February 24, 2017, 10:57:47 PM »
Just got one of these for my K11LT from the UK. $325.00 to my door. Custom built for my weight and riding style. The quality is easily on par with Ohlins. Fully rebuildable for 1/2 of price of a Progressive shock when I need to.
http://www.ramshox.com/products.html
