Author Topic: Fuel flow blockage - Clean tank, new fuel pump and cleaned injectors  (Read 5346 times)
Offline ed3541
I have a '95 K75 that has a fuel blockage. I cleaned the tank, changed the fuel pump (it works) and sonic-cleaned the injectors. Fuel line from pump to Fuel rail is clear. Fuel pump pumps a strong stream but no fuel is getting to rail. Could pressure regulator be stuck? Anyone have this problem? - I could use some help.
Love this bike and need it fixed cause it's the coolest running bike for South Florida. Right now - riding a Triumph Speed Triple but it'll be too hot for the summer.
thanx,
Ed
  • Boca Raton, Florida
  • '92 K75s '95 K75 '85 FYK100
Re: Fuel flow blockage - Clean tank, new fuel pump and cleaned injectors
« Reply #1 on: February 03, 2017, 12:04:06 PM »
Does that mean it doesn't have a blockage in it or that it doesn't have any fuel in it?
« Reply #2 on: February 03, 2017, 12:09:54 PM »
You don't mention the fuel filter. Have you replaced it? Is it oriented correctly?
« Reply #3 on: February 03, 2017, 01:56:16 PM »
Is there fuel coming out of the hose that feeds the rail?  Do you have the fuel lines connected to the correct spigots on the tank?
+1 on the filter.
Offline ed3541
« Reply #4 on: February 04, 2017, 08:14:39 AM »
Thanx for the help. I got it running. I removed the return line at the tank, pressed the starter button and got a strong stream of fuel. The engine ran and kept running when I reconnected the fuel line. So I think it was some kind of air-lock in the return line. Bike is purring again and running better than before because of new fuel pump and clean injectors.
« Reply #5 on: February 04, 2017, 08:20:26 AM »
Thanks for the update, ed!
« Reply #6 on: February 04, 2017, 10:32:37 AM »
+1.  Have you posted an photos of your brick?  Looks like a nice one from your avatar.  We always like a little K-bike porn around here.
