Author Topic: Rear brake disc  (Read 4273 times)
Offline Garf
Rear brake disc
« on: November 28, 2016, 05:30:04 PM »
Greetings, I need to replace the rear brake disc on a 87 K75S (non ABS). Can anyone suggest a after market brand and part #. The BMW replacement is mighty pricey.
Also, aftermarket pads would be great.
Appreciate any input you can give.
PS The old bolt removal was a real bummer (Heads were rounded out by previous owner so it was the drill, heat and extract routine)
  • Hartland, Michigan USA
  • 1987 K75s 2012 R1200RT
Re: Rear brake disc
« Reply #1 on: November 28, 2016, 05:43:45 PM »
You need to post what country you are in. I've used both Moto Bins, Motorworks in the UK. Beemer Boneyard in the US. EBC, Brembo, Goodridge are probably what I would go for.
Offline Garf
Re: Rear brake disc
« Reply #2 on: November 28, 2016, 05:47:15 PM »
Thanks for the reply. I'm in the USA
Re: Rear brake disc
« Reply #3 on: November 28, 2016, 06:01:38 PM »
Put the state town and country next to the bikes you own, it would be most helpful.
Re: Rear brake disc
« Reply #4 on: November 28, 2016, 07:20:41 PM »
Amazon has an EBC rotor for $179, prime, you might find a used one for $80 or so on Ebay but good luck if it's no better than the one you have now.
Offline Garf
Re: Rear brake disc
« Reply #5 on: November 28, 2016, 07:53:01 PM »
Thanks for the Amazon "Heads up"  Order placed, will be here Thursday. :clap:
