Author Topic: Saved a brick today!  (Read 50108 times)
Offline K_grendell
Re: Saved a brick today!
« Reply #25 on: December 07, 2016, 05:33:47 AM »
The hoses were the submersible type from euro moto electric that came with the kit.
  • Worcester, MA
Current bikes:
1987 k75s
1979 Vespa px200
1969 mz es-250 trophy
1997ducati 748
2007 ducati multistrada 1100s
Offline Elipten
« Reply #26 on: December 07, 2016, 06:18:09 AM »
Excellent
  • San Antonio, TX
  • 1990 K75RT
Offline nods
  • Sydney, Australia
  • 1985 K100 RT
« Reply #27 on: December 07, 2016, 07:45:45 AM »
Howdy mate, just so I know what you did (as I'm about to do the same) did you end up getting a new fuel pump, or did the original one work ok?
And have you touched the injectors yet, to get it running?
Would you mind showing me the link to the complete kit you bought from Euro Moto Electrics?
Thanks a lot, and congrats on getting her running after a 20 year snooze!
  • Sydney Australia
  • 1985 K100 RT
Offline jakgieger
  • itinerant farmer
« Reply #28 on: December 07, 2016, 07:59:48 AM »
On the injectors, this is an option.  When this set sells, it could be awhile before they get another set... IMHO, the 4 hole injector is a valid upgrade.  I am very pleased with mine (especially power-wise).  Have you removed the fuel rail to look for surprises there?
kit with bosch pump/mahle filter
  • Kansas USA
  • 1989 K100rs se
Offline nods
  • Sydney, Australia
  • 1985 K100 RT
« Reply #29 on: December 07, 2016, 08:09:05 AM »
Thank you!  So I guess that means a new fuel pump if this is the complete kit that K_grendell bought.
Those injectors looks great, but don't ship to Australia  :dunno2:  I'm wondering if it might be worth spending $100 US for those rather than cleaning and getting whatever parts are needed for the original injectors (filter? o-rings?)
Thanks again, I've saved those links.
  • Sydney Australia
  • 1985 K100 RT
Offline jakgieger
  • itinerant farmer
« Reply #30 on: December 07, 2016, 08:20:25 AM »
Cleaning your own is by far "cheaper".  The parts are readily available.  You can find the info here if you look...As far as the 4-hole injectors,  the ones on ebay are "recycled".  You could find some in Australia from an injection shop/salvage yard/wrecker!
  • Kansas USA
  • 1989 K100rs se
Offline nods
  • Sydney, Australia
  • 1985 K100 RT
« Reply #31 on: December 07, 2016, 08:24:01 AM »
Sold on that Jack!  I'm not after a fire breathing monster, so the stock injectors cleaned and working properly will do me fine.  Thanks.
  • Sydney Australia
  • 1985 K100 RT
« Reply #32 on: December 07, 2016, 01:19:36 PM »
Sold on that Jack!  I'm not after a fire breathing monster . . .
I think Jack's bike is more salsa breath with a side order of whips and chains. :giggles
« Reply #33 on: December 07, 2016, 01:59:37 PM »
Fuel pumps can often be persuaded to work again, soak in metho or white vinegar for a week or two. Then apply 12v briefly alternate the connections, working the pump forward and backwards. If the pump shows signs of wanting to move briefly try upping the voltage to 18v.
Offline jakgieger
  • itinerant farmer
« Reply #34 on: December 07, 2016, 02:11:00 PM »
I do like speed AND whips make me move faster  :hehehe ...placing me under compression...another good riding song :curvy-road .  Still not sure you have the correct innuendo Laitch pertaining to my predilections.
  • Kansas USA
  • 1989 K100rs se
« Reply #35 on: December 07, 2016, 02:18:24 PM »
Well, jack, I'm all about accuracy. Let's delete whips and chains and substitute stilettos and bustiers. :giggles
Offline jakgieger
  • itinerant farmer
« Reply #36 on: December 07, 2016, 03:11:33 PM »
You were at least on the field before.  Now, you're wandering around in the parking lot :deal: .   Are you projecting your needs/issues on me???
  • Kansas USA
  • 1989 K100rs se
« Reply #37 on: December 07, 2016, 03:42:04 PM »
Not yet, jack, but I'll consider doing that if it's ok.  :hehehe
Offline nods
  • Sydney, Australia
  • 1985 K100 RT
« Reply #38 on: December 07, 2016, 05:02:08 PM »
Thanks Martin, I've seen someone pulled the pump apart too
Sent from my SM-G925I using Tapatalk
  • Sydney Australia
  • 1985 K100 RT
Offline jakgieger
  • itinerant farmer
« Reply #39 on: December 07, 2016, 07:40:18 PM »
NOT OK. :yow   We really should stop :threadjacked .  We might be starting to give the asylum a bad reputation.  People might think we really are Krazy. :bmwsmile
  • Kansas USA
  • 1989 K100rs se
« Reply #40 on: December 07, 2016, 07:48:05 PM »
You're right, of course, Jack. In fact, you took the words right out of my mouth. :giggles
Offline bmwpyro
« Reply #41 on: December 07, 2016, 11:41:54 PM »
umm. too late? but good Krazy  :yes
  • Azusa, CA
  • 1985 K100RS, 1990 K75S
Always Learning...
Always something new to learn about riding and Kbikes...
"Viam inveniam aut faciam"
Offline K_grendell
« Reply #42 on: December 08, 2016, 11:21:00 AM »
This threat just got really hot!
Nods that link above is what I ordered. Make sure to get the optional filter, and submersible lines that are listed.
I haven't done injectors yet, but I'm going to order the recycled 4 hole nozzles. If I'm going into the fuel rail I'd rather replace everything so it's new and Ethanol compatible I like doing things just once if possible, and I hate to get stranded from lack of due diligence.
  • Worcester, MA
Current bikes:
1987 k75s
1979 Vespa px200
1997ducati 748
« Reply #43 on: December 08, 2016, 11:44:22 AM »
There's not much indication that four-hole injectors greatly enhance performance of the K75; there is some indication that the fuel mixture might need a slight modification to get the engine running optimally after they are installed..
« Reply #44 on: December 08, 2016, 12:04:39 PM »
I have been told 4 hole injectors work if they spray directly into the combustion chamber. As this is not the case with the K engine, there is probably nothing to be gained. The performance gains felt on converting, are more than likely the result of new clean injectors against old dirty ones. Until somebody does a Dyno comparison with cleaned and serviced 1 hole injectors against clean serviced 4 hole injectors it's all conjecture.
« Reply #45 on: December 08, 2016, 12:16:14 PM »
I have been told . . .
What if I tell you that using lavender talc on a K75 to detect oil leaks attracts land crabs that will puncture the tires?
« Reply #46 on: December 08, 2016, 01:23:21 PM »
One thing to consider about 4 hole injectors beyond that there is no measurable performance difference reported, is that in order to flow the same amount of fuel, the nozzle orifices will necessarily be a lot smaller than what are found in single hole injectors.
Being a mechanical pessimist, when I think of smaller orifices, I think "easier to clog".
« Reply #47 on: December 08, 2016, 01:44:11 PM »
Laitch show me pictures, or a certified report on land crabs being attracted to Lavender talc, and I will believe you.  :dunno On the subject of the injectors, even Osidetiger haven't done a Dyno report on the differences that I can find. Until somebody does a Dyno report it is still conjecture. I would love to find a report either way. Could please over winter build a dyno out of old snow plow parts and submit a report.
Waiting patiently Martin.
Offline jakgieger
  • itinerant farmer
« Reply #48 on: December 08, 2016, 08:56:55 PM »
WHOA NELLIE :nono , Threats on this site are strictly forbidden.  The last moderator had to take a leave for behavior such as this :deal: .  HOWEVER, smart a## remarks, questionable humor, vague references, passive aggressive remarks/demands, implied violence, and just general ignorance, are not only condoned but encouraged by the inmates.
To all you people named Thomas, the four hole is an improvement on the injector.  Yes, Gryphon, it has a smaller hole.  I personally like smaller holes, since they--- "For gasoline to be burned, three things need to occur. It must be atomized (broken into small particles), emulsified (mixed with air), and vaporized (changed into a rarefied form). The job of the injector is to prepare the gasoline to make the phase change from liquid to vapor."
  • Kansas USA
  • 1989 K100rs se
« Reply #49 on: December 08, 2016, 09:16:37 PM »
I personally like smaller holes . . .
Me, too. It's a preference that unites this great country from the Left Coast to the majestic Great Divide and bountiful Midwest then onward to the effete Eastern Establishment and humidly devout South.
