Author Topic: BMW Virgin  (Read 8530 times)
Offline Supershooter
BMW Virgin
« on: November 20, 2016, 10:04:53 AM »
Hello all,
Long time American built rider who bought a winter project bike that happens to be a 1985 K100 that doesn't run/ hasn't ran in over 10 years. I'm debating wether or not to keep it stock or transform into a cafe racer or GS.
Supershooter
  • 85 K100 RT
Re: BMW Virgin
« Reply #1 on: November 20, 2016, 10:11:31 AM »
Welcome, Supershooter!
I think that particular debate is premature. Usually the first debates are whether to sell it for scrap metal or part it out, or whether to get parts by using a home equity loan or a gofundme campaign. :giggles
Re: BMW Virgin
« Reply #2 on: November 20, 2016, 11:48:19 AM »
Welcome!  How many miles?  Any photos that show the general condition?
Re: BMW Virgin
« Reply #3 on: November 20, 2016, 11:56:18 AM »
K100's are horrible candidates for cafe's or GS's.  Try making a sporty, tourable, commuting, grocery getter, all around workhorse bike, Hey that sounds like a RS!
Re: BMW Virgin
« Reply #4 on: November 20, 2016, 12:20:25 PM »
Welcome to the asylum from the land of OZ. Assess it first most Bricks are recoverable but at a cost, time and money.
Re: BMW Virgin
« Reply #5 on: November 20, 2016, 02:28:15 PM »
Loaded and heading home.
Supershooter
  • 85 K100 RT
Re: BMW Virgin
« Reply #6 on: November 20, 2016, 02:30:17 PM »
Saddle bags, battery and other parts are in the pickup
Supershooter
  • 85 K100 RT
Re: BMW Virgin
« Reply #7 on: November 20, 2016, 03:04:00 PM »
Looks reasonably clean, where and how was it stored? Lot's of information available on how to resurrect Bricks on this site. Don't be tempted to try and start it until you have done the must do basics. Change the oil and filter, check coolant level, replace the fuel lines and filter, clean out the tank check the condition of the fuel pump damper and test the fuel pump. Check and clean air cleaner element, critters can nest in there, check spark plugs, check the Z breather hose and all the rubber bits, hoses, throttle body rubbers. Once it is running then you can proceed on to brakes suspension cooling system fluid changes.  Don't be tempted to ride it until you have replaced tyres and got the brakes flushed and functional, cooling system flushed and functional, gearbox and final drive oil changed. It will probably smoke on start up, this is normal and will settle after you put some miles on it. Bricks don't like to be left sitting (especially on their side stand) and electrical problems can surface Deoxit will be your friend, I also use dielectric grease to keep moisture out. You have a long fun road ahead of you. If you have any problems the inmates love pictures and sound recordings and as much information as you can supply.
Good luck regards Martin.
Re: BMW Virgin
« Reply #8 on: November 20, 2016, 03:17:48 PM »
Martin has adroitly summed up the essentials.
I have a couple of observations to add. Your bike's fuel tank cap is mounted backwards. It should open from the forward side and its hinged flange has a notch that aligns with a hole beneath to allow water to be drained away from the tank opening.
I'll add shadow puppets to the list of inmate loves.
Re: BMW Virgin
« Reply #9 on: November 20, 2016, 03:45:16 PM »
Well observed Laitch on the fuel cap.
Offline jakgieger
  • itinerant farmer
Re: BMW Virgin
« Reply #10 on: November 20, 2016, 06:11:27 PM »
Welcome.  The bike looks relatively straight...perhaps a candidate for restoration.  What is the mileage???  Take off the fuel lid and see what surprises are waiting for you there :bmwsmile.  My bike had sat for over 10 years, with a mostly full tank of gas and in a vermin infested barn :hehehe.  Now you see it in the avatar.  Good luck either way.
  • Kansas USA
  • 1989 K100rs se
Re: BMW Virgin
« Reply #11 on: November 20, 2016, 06:43:24 PM »
arrgh, the horrid "lets match the spark plug cover to the bodywork" theory of K bike Kustomizing.  One can only hope it falls over on it's left to hide that atrocity!
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: BMW Virgin
« Reply #12 on: November 20, 2016, 06:56:41 PM »
Stock! they are a great all round bike and the protection provided by the fairing makes it comfy on the cold days.
  • Waldport, Oregon
Re: BMW Virgin
« Reply #13 on: November 20, 2016, 06:58:44 PM »
The back story would include a friend of a friend lost her brother and inherited the bike, after it had sat for 10 years or so, maybe more. Her husband decided to try and make it run, so he started messing with it. I think he tried to start it already, but figured it had a fuel pump problem as it would turn over but not start and run. The keys were lost and replaced with a new ignition, and they broke into the fuel cap. I smelled the fuel this afternoon and it stinks like it has varnished the inside of the tank. I inadvertently missed getting all of the parts that were supposed to come with the bike. So Ill be getting them this week as we find a ride for them since we live 350 miles apart.
Supershooter
  • 85 K100 RT
Re: BMW Virgin
« Reply #14 on: November 20, 2016, 09:30:31 PM »
Fuel pumps can be revived by soaking in vinegar or methylated spirits for week or two. If they feel like they want to go but feel stuck, switch the leads over and alternate back and forth in short bursts, this sometimes get them going. As a last result, up the voltage to 18v and alternate the direction back and forth in short bursts. If the pump is not working also check the 4 pin plug under the RH side of the tank it has known connectivity problems.
Re: BMW Virgin
« Reply #15 on: November 20, 2016, 10:03:58 PM »
That's a sad backstory, Supershooter.
The bike is better off that it didn't start so no more degraded fuel and chunks-of-whatever travel throughout the fuel system. The fuel pump might be the problem but clogged injectors might be part of it, too. Also, these bikes depend on electronic engine management systems so all electrical connections must be in good shape to have the best chance at success.
Offline jakgieger
  • itinerant farmer
Re: BMW Virgin
« Reply #16 on: November 20, 2016, 10:04:24 PM »
If you can't save it (the pump), these guys http://www.euromotoelectrics.com/BMW-K-Parts-s/60.htm have helped me at affordable prices.
  • Kansas USA
  • 1989 K100rs se
