Author Topic: WTB Engine heat screening for K1100RS  (Read 7685 times)
« on: November 11, 2016, 01:06:46 PM »
As part of my project to install the K1100RS fairing on my K100RS I am looking for the following heat screenings parts in case nay one has some.
Part numbers
Diagram part 01 - 13 72 2 309 349
Diagram part 03 - 13 72 2 309 963
Diagram part 04 - 13 72 2 309 972
Diagram part 05 - not sure of the part number for this one it isn't shown on the MaxBMW fiche
I already have Diagram part 02
Thanks
Re: WTB Engine heat screening for K1100RS
« Reply #1 on: November 29, 2016, 10:59:38 AM »
Bump  bmp
« Reply #2 on: November 29, 2016, 12:12:35 PM »
Part numbers
Those part numbers is for the K1100LT
« Reply #3 on: November 29, 2016, 12:18:02 PM »
According to RealOEM they fit both bikes - at least I hope they do!
I have also managed to find the part # for no. 5 - the missing one in the original post - 13 72 2 307 556
« Reply #4 on: November 30, 2016, 02:25:31 PM »
From RealOEM, heat screening part numbers for K1100RS and K1100LT.
« Reply #5 on: November 30, 2016, 02:42:00 PM »
They are the same parts with different part numbers  but since no one has any to sell it doesn't really matter either way
« Reply #6 on: November 30, 2016, 03:05:29 PM »
They are the same parts with different part numbers . . .
Keep in mind BMW uses often uses generic drawings to indicate parts (recalling the crankcase vent hose diagrams) but in composition, the parts differ considerably, and in your case, the prices for the parts numbered by diagram are substantially different.
These parts may appear in used part market in the future. Before you purchase, I think you should consider that the price differences (such as the discrepancies between parts that are numbered 2) shown in Inge's diagrams indicate parts that are designed differently for the RS than for the LT.
« Reply #7 on: November 30, 2016, 03:10:38 PM »
I am more than happy to agree with you both that they are different parts.
it was this that confused me, I guess RealOEM has it wrong or they use the same part number for various bits - if I click the hyperlinks on that page to the diagrams for the various models it shows me a completely different part depending on which link I click
That is kinda worrying. Living in CR as I do returning an incorrect part is a costly and time consuming process.
« Reply #8 on: November 30, 2016, 03:21:12 PM »
Yep, that's confusing—and given Inge's data—probably inaccurate, and ultimately disappointing. Given the interest in cafe racers though, diligence on the Web could produce an RS being taken down somewhere into parts just waiting for you. This is the main reason to encourage the cafe racing trend.
Have you seen these parts in person? Maybe they can be fabricated out of styrofoam and craft-brew aluminum can stock wrapped in Reflectix. :giggles
« Reply #9 on: November 30, 2016, 03:21:55 PM »
See?
No I haven't seen them in person, just the one piece I do have no 2 - depending on which diagram you look at!
« Reply #10 on: November 30, 2016, 03:37:19 PM »
+1 Laitch. Filmcamera given that these parts are to block the heat from getting to the rider, manufacturing them should be possible. We have a shop called Clark Rubber ( US should have similar but better)  and they sell varying thickness of high density foam rubber. Having seen these parts on a K75 RT 1/2" thick looks ideal. Armed with foam rubber contact glue, aluminium tape, Refectix and a contour gauge and cardboard to make templates it would be a challenging but rewarding project.
