Author Topic: 85 K100 won't shut off  (Read 4072 times)
Offline smith913
« on: October 31, 2016, 07:49:26 AM »
I am having issues getting it to shut off via key or kill switch. The only true fire way to power down is to pull fuse 1. possible ICU issue? Otherwise I'll check to see if the starter relay is fused, could that be the cause?
Already cleaned ignition switch and starter brushes
  • Alexandria, VA
  • 1985 K100RT
Re: 85 K100 won't shut off
« Reply #1 on: October 31, 2016, 07:57:56 AM »
A stuck starter relay wouldn't cause this issue.
The FI relay could be stuck on though.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline smith913
« Reply #2 on: November 01, 2016, 11:34:01 AM »
FI relay is good, I may double check the starter, but I'm at a loss
  • Alexandria, VA
  • 1985 K100RT
Offline jay1622
« Reply #3 on: November 01, 2016, 02:31:16 PM »
I'm not sure if this schematic will help, but I remember using this to diagnose mine.
  • Charlotte
« Reply #4 on: November 01, 2016, 06:26:42 PM »
When you turn off the ignition switch, what happens?  Do the lights go out?  Do the instruments shut down?  Does everything keep on working?
You mentioned that you were in the ignition switch.  Are you absolutely certain that you put it back together correctly?
A little more information will help a lot.
Offline TrueAce
« Reply #5 on: November 01, 2016, 09:49:21 PM »
Your starter button is sticking, needs careful cleaning to not lose parts :euro.
  • Florida
Offline smith913
« Reply #6 on: November 02, 2016, 10:16:33 AM »
I haven't checked the headlight, but everything else is still on. Almost as if the key/kill switch didn't do anything, I could probably go for a ride if I wanted to. Instruments stay on, I am using the acewell 2853 though.
I tried a spare kill/starter switch I had laying around so it's not that it's sticking. I'm pretty sure the ignition switch is correctly assembled.
  • Alexandria, VA
  • 1985 K100RT
