Author Topic: Front Brake Handle Pressure  (Read 5897 times)
Offline 313green
« on: October 29, 2016, 11:12:20 AM »
hey guys. i did some mods to my bike. i can't recall, when I depress the front brake handle, does it move all the way into the grip (like the clutch). I remember it doing that but now it only depresses a small amount. Still brakes but it has no play. Is it as simple as adjusting the tension or is this a fluid issue? I did remove the front hose to replace handlebars.  Thanks :bmwsmile
  • detroit
  • 1985 K100 Naked
Re: Front Brake Handle Pressure
« Reply #1 on: October 29, 2016, 11:38:24 AM »
Did you install new pads and braided stainless brake lines?  Did you do a proper bleed of the system?  That will tighten up the action at the lever.  If the lever used to go to the handle before, it may have been a combination of old pads and a lot of air in the system.
If the brakes are stopping the bike properly and the wheel spins freely when they aren't being applied, I would say you have done well and are good to go.
Offline kennybobby
« Reply #2 on: October 29, 2016, 02:45:13 PM »
Brake lever should never come in all the way to the grip.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
« Reply #3 on: October 29, 2016, 09:16:36 PM »
Brake handle should not move much.  Sounds like it is working as designed now!
Offline jay1622
« Reply #4 on: October 30, 2016, 03:58:44 AM »
+1
If the wheel spins free w/ no brake, but the brakes grab at application, you're where you should be.
  • Charlotte
