Author Topic: What Constitutes "Disassembly" of the Fork?  (Read 4256 times)
Offline Jnclem
« on: October 15, 2016, 08:28:51 AM »
A few weeks ago, I set out to simply replace the seals and install gators on my K1100LT forks. Unfortunately, I got everything jammed up on one side when a lower bushing got deformed. I was able to remove the lower with heat, and without having to cut it in half, so that was good.
I now have new lower bushings, and another set of new seals installed, and I'm getting ready to reassemble everything. I HAVE NOT removed the fork legs, or disassembled the cartridge, I have just pulled the lowers off. However, the lowers have been off now for three weeks. Do I need to refill according to the changing the fork oil instructions, or according to the disassembly instructions? In other words, do I need to refill with 350 and 400 cc's, or with 400 on both sides?
Thanks.
  • Gunnison, CO.
  • 89 K100RS SE, '89 R100GS, 2006 F650gs Dakar
Re: What Constitutes "Disassembly" of the Fork?
« Reply #1 on: October 15, 2016, 09:02:14 AM »
How do your instructions define disassembly? I define it as removing the fork assembly from the triple tree and removing all the parts within each side.
Offline Jnclem
« Reply #2 on: October 15, 2016, 10:04:10 AM »
That's what I would think. But it isn't that clear. The two categories are drain and fill, and disassemble. I would say I have partially disassembled by not just removing drain plugs, but taking the lowers off and emptying them. I don't know if there is another 50cc's inside the cartridge side or not, as I have never removed one.
  • Gunnison, CO.
