Author Topic: Found, Clutch boot leaking. 87 K75C  (Read 31473 times)
Offline trek97
  • The Anti-Cafe racer
« on: October 08, 2016, 05:25:39 PM »
Hey guys,
Found some oil on the floor and after some investigation, did a search and found this article seems to agree w what I got going here.
http://www.motobrick.com/index.php/topic,2883.msg16783.html#msg16783
But please take a look at my pics and if you agree/disagree please let me know.
Plan to order new cup from bobsbmw.com at $45.35.
Please let me know if you have a better resource.  THANKS!
  • Illinois
  • 87 K75C
Re: Clutch boot leaking?
« Reply #1 on: October 08, 2016, 05:30:22 PM »
I would very, very carefully remove the boot and check it closely for splitting before I spent $44 on a new one.  But that's just me.
Offline trek97
« Reply #2 on: October 08, 2016, 05:33:27 PM »
Yep, looking for it in manual now.
  • Illinois
  • 87 K75C
« Reply #3 on: October 08, 2016, 05:46:30 PM »
If it is split, I would give it a very good cleaning with a paint prep degreaser like PrepsAll and give the split a shot of super glue or possibly the stuff they use for sealing retrofit CV joint boots.
« Reply #4 on: October 08, 2016, 05:54:14 PM »
Finally we have something cheaper than the US clutch boot $25.00 Au plus $3.50 freight on Ebay. While you are doing it you might want to fit a grease nipple to your clutch arm, it keeps all the crud and water out.
Offline trek97
« Reply #5 on: October 08, 2016, 06:01:44 PM »
I was kinda thinking that way.  If its pretty easy to remove/re-fit.  But if its a bear to get off/on there I may not want to do it again next month.
Im finding very few parts like this on ebay here in the USA.  I was looking at the needle roller bearing in the manual and thinking.  Now why wouldnt they have put a zerk on that?  HA!
  • Illinois
  • 87 K75C
Offline trek97
« Reply #6 on: October 08, 2016, 06:05:15 PM »
But, what Im really wondering is why there isnt a real seal somewhere behind that boot around the clutch push rod to begin with?
  • Illinois
  • 87 K75C
« Reply #7 on: October 08, 2016, 06:11:31 PM »
Due to the size of it might be cheaper to get one from OZ via post. It might be worth contacting him. I am actually thinking about getting one to add to my collection of spares.  http://www.ebay.com.au/itm/BMW-Clutch-Actuation-Pushrod-Rubber-Gaiter-K75-K100-K1100-/142098201573?hash=item2115b67be5:g:DhwAAOSwEjFXc8YK
« Reply #8 on: October 08, 2016, 06:15:02 PM »
Also check that the clutch is correct adjusted.
If the arm have to much angle from where it should contact the sealing surface on the boot,
the spring inside the boot won't be able to add a even pressure all around in the boot...against the lever arm.
« Reply #9 on: October 08, 2016, 06:16:42 PM »
It is.....inside the end of the gearbox shaft......to prevent the gearbox oil from reaching the clutch.
Offline trek97
« Reply #10 on: October 08, 2016, 06:26:08 PM »
I have a lot to learn about these BMWs.   :dunno
So is this what you are telling me?  I have a seal deep inside there leaking?  and the oil is running down the push rod to reach this boot?
  • Illinois
  • 87 K75C
Offline trek97
« Reply #11 on: October 08, 2016, 06:28:26 PM »
Its looking like I got to pull the exhaust off.  To get the pivot pin out.  ugh!
  • Illinois
  • 87 K75C
Offline trek97
« Reply #12 on: October 08, 2016, 06:31:30 PM »
Heck $25 AU cnoverts to $18.97 US.  I bet shipping is high and would take forever to arrive.
  • Illinois
  • 87 K75C
« Reply #13 on: October 08, 2016, 07:04:34 PM »
Just checked the listing.  $24.05 US for shipping to U.S.  No reason to buy from this guy.
Offline trek97
« Reply #14 on: October 08, 2016, 07:39:54 PM »
Got things as clean and dry as I could.  Bout a 1/2 a cup of mucky gravel and sand in there.
Couldnt find any obvious tear in the boot from this angle.
Tucked a couple white kleenex under the suspects.  Ill check back in the morning.
  • Illinois
  • 87 K75C
Offline trek97
« Reply #15 on: October 08, 2016, 07:45:08 PM »
Hey Martin the grease zerk is a super idea!
  • Illinois
  • 87 K75C
« Reply #16 on: October 08, 2016, 10:36:38 PM »
$24.05 seems awfully dear for something you could just stick in an envelope and post. :dunno
« Reply #17 on: October 08, 2016, 11:06:02 PM »
Just checked Ausralia Post prices to US        Use your own envelope
Send a letter up to 500g for a flat rate.
Product
Size
Weight
Price
Letter (50g)
Up to 260 x 360 x 20mm
Up to 50g
$2.95
Letter (250g)
Up to 250g
$8.00
Letter (500g)
Up to 500g
$18.00
Use our prepaid envelopes
Send your letter for a flat rate using one of our postage-prepaid envelopes.
Product
Size
Weight
Price
Small envelope DL
110 x 220 x 5mm
Up to 50g
$3.25
Large envelope C4
229 x 324 x 20mm
Up to 250g
$8.80
Offline trek97
« Reply #18 on: October 09, 2016, 07:03:30 AM »
I checked and found clutch was out of adjustment, THANKS, Inge K! (78mm)
So I got it set at 74.6mm, re-set the rod push bolt at the lever and free play at the control. The boot now looks to fit a bit better.
Also lubed the barrel.
The oil smells of gear oil.  So apparently that is completely normal as there is no inner seal to prevent this.  Though there is an o-ring in there that could be bad.  Im not exactly clear what the o-ring does...maybe its what keeps the oil from traveling into the clutch disk?
Got things dried out again and gonna wait and see if the mis-adjusted clutch was the culprit. (deforming the spring and not applying even pressure around the boot OR the boot is just showing its age and needs replaced.)
I will report back later.
Thanks guys.
  • Illinois
  • 87 K75C
Offline Motorhobo
  • +25 years of K75
Re: Found, Clutch boot leaking. 87 K75C
« Reply #19 on: October 09, 2016, 07:38:25 AM »
At the recommendation of my buddy Mike B who was a BWW mechanic in the classic K era, I put a small dab of blue RTV sealant at the joint between that boot and the clutch arm.
Offline trek97
« Reply #20 on: October 09, 2016, 07:53:33 AM »
Sounds like a good idea.  If I find it needs to be repaired/replaced I will do that.
  • Illinois
  • 87 K75C
« Reply #21 on: October 09, 2016, 07:58:02 AM »
The oil smells of gear oil.  So apparently that is completely normal as there is no inner seal to prevent this.  Though there is an o-ring in there that could be bad. Im not exactly clear what the o-ring does ...maybe its what keeps the oil from traveling into the clutch disk?
Where is this o-ring located?
« Reply #22 on: October 09, 2016, 08:02:19 AM »
+1. I've also used this metod on a couple of this boot that haven't been so cooperative.
Offline trek97
« Reply #23 on: October 09, 2016, 08:05:02 AM »
If the clutch adj doest do the trick maybe I will pull it and give it a soak in Wintergreen oil and try the RTV.
  • Illinois
  • 87 K75C
« Reply #24 on: October 09, 2016, 08:25:59 AM »
