Author Topic: New Member, K100LT  (Read 4732 times)
Offline dave33333
New Member, K100LT
« on: October 04, 2016, 07:46:30 PM »
ok, just picked up a K100LT.  It's an '87 with 42K miles, paid $1800.  So far I've put on new tires (Metzler Sportek Klassik), new front brake pads (Semi-Sintered), had a local hose shop fabricate new ss brake lines front and rear for $120, flushed the brake fluid, replaced the torn rubber cup at the rear of the transmission (what a mess!) and adjusted the clutch, changed the air filter, purchased all necessary parts for oil/filter change, final drive fluid change, transmission fluid change including new sight glass, coolant change.  That will hopefully happen this weekend.  Have set up the powerlet on the dash to charge my cellphone, removed the PO's CB Radio, purchased aftermarket bag liners off of ebay, ordered new keys from motokeys.com using the codes from PO.  Purchased crankcase breather hose, will replace fuel hoses using gates lines as well as the fuel filter, will lube the final drive splines.  Replaced grips and headlight bulb.  Should then be up to snuff.  Pic attached
  • Walnut Creek, CA
  • 1987 K100LT
Re: New Member, K100LT
« Reply #1 on: October 04, 2016, 07:51:55 PM »
Nice looking bike, welcome!
Looks like you have the bases pretty much covered, now ride and have fun...
Offline F14CRAZY
« Reply #2 on: October 04, 2016, 09:20:21 PM »
Yeah it's worth it to get all that stuff out of the way and not have to worry about it or have issues to troubleshoot related to that stuff
  • Grand Rapids, MI
  • '87 K75C
« Reply #3 on: October 05, 2016, 01:33:37 AM »
Welcome, dave. Good looking bike and you're on the right track with it.
« Reply #4 on: October 05, 2016, 03:33:22 AM »
Welcome to the asylum from the land of OZ.
